HellFire Concrete Coating, Easy, Tough!
calicrewchief
Coincidentally, we are currently working on the discoloration as customers want to use this level of protection in more “decorative” applications.
Of course, we will work with any former client that wants to topcoat with the newer formula.
Lastly, the solution to this is coming from a famous German automobile manufacturer. Rhymes with Mercedes-Tenz.
Will update when ready.
Wow! Great customer service! I'm sold on Hellfire. I look forward to our future transaction.
ivan256
I’m planning to finish a 30x40 slab in a few weeks and I’m down to deciding between Hellfire and Rust Bullet. Is the change that was being made to prevent yellowing available yet?
L
LegacyIndustrial
deerfield, IL
Ivan:
It never yellowed, the product took a drab hue.
We are working on it still, an announcement will be made when completed.
Thanks for considering us and hang in if you can!
js79
1 year later. Progress report on the new product? Mine are pretty horrid.
Sent from my POCOPHONE F1 using Tapatalk
L
LegacyIndustrial
deerfield, IL
After seeing pics, this floor looks a little rough due to a clear-coat not being applied over the flakes. Not a fan of flakes with HellFire to begin with for a variety of reasons.
Regardless, we will gladly supply enough HellFire V2 to help you get this floor on the right track, remember to always clear your flakes for protection!!
:beer:
HodgeSpeed
home
How long does this coating last compared to a high solids epoxy? I’m down to this or the 1000hs from sherwin Williams.
L
LegacyIndustrial
deerfield, IL
Apples and Oranges....
HellFire is a protective , metal fortified, sealer. Thin by design and much more chem resistant.
High-Solids Epoxy offers colors, greater mils thickness and more $$$$.
Mils thickness is beneficial when your traffic is very high. Chem resistance is beneficial when you are doing a specific task in the space that involves harsh liquids.
Maintenance of the space also comes into play.
Thanks
Coloradical
Colorado
We’re looking into floor coating options for this room in our shop and I mentioned Hellfire to my boss and he’s interested.
What should be our prep if we used hellfire, I mean would just using the acid etcher suffice for prep on this surface? The room is approximately 250sqft
Shea
California
That looks like old paint on the floor? If so, you will need to grind to remove it and prep the surface at the same time.
moore87
Waco, TX
Use 400 sq ft per gal, per coat.
Coat 1 will be under 400
Coat 2 will be at 400
Coat 3 will be over 400
Therefore, 400 sq ft per gal is a good average, per coat.
3 Coats will be enough to eliminate roller marks and have complete even coverage? I assume coverage is the same for the new formula vs old?
I am interested in a kit for a 1575 sq ft floor
esvee
Portland, OR
I did Rust Bullet on my first garage and this looks very similar with a lower pice, which I can definitely get behind.
My last garage was a slippery nightmare when wet so I'm considering softskid. What do you recommend for the application process?
L
LegacyIndustrial
deerfield, IL
We have seen flawless floors turned in where the user was careful and some that were slightly visible. The heavy metal additives make it slightly tougher than other high-performance coatings to roll out.
Take your time on the 3rd coat and you should be fine.
1MtnGoat
Cleveland, TN
Here are a few shots of my floor with Hellfire applied. Also used their crack filler. Once ground the expansion joints are nearly invisible. Hellfire has held up well to jack stands and floor jack. So far no visible sign of use. Easy to apply.
esvee
Portland, OR
How slippery is it when wet?
rednorseman
0b988uHXI6DKBfpbTQTm0Vrvhid-uVjB-Snmue2C9fSOqTMnEuUurftPzGuFJse3CJbyfo_lSkhTmm7dD9FRK_WSDgmevNjGsNinyCdR3MLhNEwF5xhUtZkONMCBPLC3p_a6pF-TPaSTP36wDUYdAp9d0DTWksKFHoB0y5M99b6EULyFXaD1p2SXQBsd1l8ESMrdp75NdK8iEWvTnyBfEugtzLhVJRSKsosBCxel92nipfzQpnnaWIAnaI2LND2-fiCNZGa1gxmar4SGpqcxBmjfMq6Y2vfb6WQrhVquV4D7U_f-A5g7ornU54k3a0CL8fZdHlLPlpc16HWngw7G80GD19KXXeBD6PlIt2anc5rVCyxj6h_sKu5ssTW8v0uPdhUWGLzvO3fH-ppZrngl-A5IFxjn8CAo0qLxKn5hG-pTMi62NQ-bEwC5Dlhugl86tUqT4A22qqgkS2DapdfE1Sofae6ZKbUXwlEWgNvqk8UyrHojY8QnccVvkWLCgFah0dhY81W3slURBVsylTly6m6UA6p5q1YuALemojKuJx_kvtiWcc0T0_JpjoKY4w0ugLfClGBqKcOLF8TdOQwM2MgAUZ1pygTW6K6aSqfGgBe-kWA8wOXU9JJ7yfKt121Bxl5O2FVVsXGhfmJxl7kqcGiS2_sV9fstJiOgBkx1jR7nmXrNzccVQXs=w1347-h1010-no
Scotty,
I bought ~15 or so gallons of the Hellfire v1 about two years ago, and while the floor has held up well to chemical and mechanical abuse, the UV damage makes it look like a mottled mess, with varying degrees of pure gray to mustard brown, depending on what was covered from what angle.
Does the second version of Hellfire prevent this? Can you use the new version over the old? Is there any remedy for the discoloration on V1?
L
LegacyIndustrial
deerfield, IL
Scotty,
I posted a while back, anyone who purchased V1 can contact me for a free topcoat of V2, shoot me an email and we will get you set-up. The V2 is the remedy.
Black300zx
Elkton, Md
^^^That looks just great. All of these really clean hellfire installs make me a bit jealous since my install has some rollermarks in the last half because I had to stretch the last gallon. Looking at the TDS, recaots can be done after deglossing w/ 120grit screen or an appropriate stripper pad?
It's been about 4 months since I did mine. If I get the energy, would you reccommend against using the prep mentioned above to apply another coat or two to spruce up the final finish?
L
LegacyIndustrial
deerfield, IL
Check this link:
https://www.legacyindustrial.net/pdf/RecoatingResin_AcrylicSystems.pdf
“Partial or no-flake floors without clear-coat”
rednorseman
Scotty,
Thanks for the quick response, and the complimentary shipment of Hellfire V2. Looking forward to getting the top coat on there.
Jesse
bdk1976
Just laid down about 720sq for of hellfire yesterday in part of my shop. Went down great - LOTS of careful back rolling seemed to keep roller marks to a minimum. @
However, I am a bit concerned with coverage as put down three coats over a freshly ground surface and only used 3.5 gal total for three coats(!). Going by the estimates I should have used over 5 gal for this space?
I know there is always variation due to surface/techniques. I did use fairly light coats with a lot of back rolling to avoid roll marks/etc. Do I need to condisider adding more product or will three solid - if thin- coats be okay? Ultra fine “grip” added to last coat.
Any similar experiences with hell fire or other “POR15ish” (my term - these seem to be in the same chemical family) floor products (rust bullet, etc.) with coverage like this?
L
LegacyIndustrial
deerfield, IL
BDK:
How much you use has less to do with Coat 2 & 3 and more with Coat 1.
If your floor wasn't very porous this can skew coverage.
In your case , if still in the coating time window, add another coat.
If out, then prep accordingly for another coat.
3 coats is the minimum for a great looking floor.
Thanks for sharing.
js79
Hi folks I'm back from sea duty. Nation called and required some time, actually a little longer than some time. But that's besides the point.
I am back and would like to fix my garage from version 1 hellfire. My Tapatalk just upgraded so I trying to catch up and read all my subscribed threads. Scotty will you let me know how much it would cost, for me to redo my garage?
L
LegacyIndustrial
deerfield, IL
Welcome back Sailor!!
Send me an email and we will get you hooked up. If you are a V1 customer then you will pay nothing for the topcoat.
TimTaylor75
Lecanto, Florida
Closing on my new home near Crystal River next month and am looking at products similar to HellFire for my new 22'x22' garage. There is some sort of coating applied currently, but I have plans to grind the floor prior to moving anything in. You guys are only about 90 minutes from me, do you have a showroom or local customer spaces available to view?
L
LegacyIndustrial
deerfield, IL
Tim we do not, although for the amount of inquiries we get, we should! :bounce:
I think you have plenty of members to reach out to here on the forum to chat with.
and btw... just had another customer post on Google regarding HF...
Thanks.
Evilcactuar
Connecticut
I've got a stupid question, what are people doing for the apron? I assume you don't recommend putting down hellfire there, as it looks like v2 still fades somewhat, and I would guess you want to seal it with something so it doesn't absorb water (though I could be over thinking it)
Black300zx
Elkton, Md
I'd be interested as well. The color shift isn't bothersome to me, but I notice it. I've contemplated one of those rubber garage door thresholds. The discoloration is minor enough that if the faded/normal transition was masked it wouldn't even be noticeable.
L
LegacyIndustrial
deerfield, IL
If desired, you can go to your local paint store, get a quart of breathable, acrylic deck-coating in a similar color. This will obviously be less protection but better for the outdoors.
Thanks
