Wayne compressor info
AA7483
South Jersey
Can anyone give me any info on this compressor . I can see its a single phase motor but thats it. Guy is asking 400.
Citation
Indy
Hard to say. Is it a 15A motor? If so a new, similar compressor is $400-500. It looks like a 60 gallon tank. It doesn't have a magnetic starter so it's likely a 15A motor. It could be a 5hp (22A) but probably not. Looks like a quality 2 stage pump but it's also used and in unknown condition. In known good shape it's probably a better compressor than the 60 gallon pro-sumer stuff at the big box stores. However as it costs the same and it's in unknown condition I would be reluctant to bite. Just my opinion which may be worth little more than you paid for it.
mikegt4
sw ohio
Wayne made excellent compressors. A search of the "general tools discussion" forum will list several threads. It is hard to tell from the photo but it looks like it may be a 376 or 396.
kbs2244
Seems high.
Is it in service so it can be shown to work?
If taken out of use, WHY?
A
AA7483
South Jersey
Upgraded to something larger. Was working when in service apparently. With no specs ill likely pass
greg13
Weedsport, NY
It's not the deal of the day, but it's not a total rip off either.
Walk in with 3 $100 bills & 2 $50s, wave the 300 first and see if he bites. if not pull the first 50. If you are really serious pull the second and call it a day.
coljar
Belpre, Ohio
I was thinking $300 also, but only if it runs.
c39er
Seattle, Washington
Parts are hard to find for these Lei Roi Dresser..... AKA Wayne compressors...I had to rebuild the head on a 120 gallon unit...Good units though.
A
AA7483
South Jersey
Thanks for the info guys. I decided to hold out for something different. May have felt differently if I had some specs but I'm sure something else will come along.
metlmunchr
Every vertical Wayne I've ever seen has spent the majority of its life in a gas station. Good compressors, but as with anything, there's a limit on how many thousand hours it can run until its worn out. Definitely not worth $400.
