Finally got my HF Air/Hydraulic 20T jack to replace the slow manual unit in the HF 20T press... should make dimple die, and press brake work faster!
On sale at $79.99 last week.
Oh, and air hose reel too.
Been busy chipping away at the Airstream list...
Sealing leaks, and lowering interior temperatures in one by painting the roof white with Henry's Enviro-White roof paint.
People are reporting a 20f interior temp drop just from the white paint reflecting/rejecting heat better than polished Aluminum, so I was in!
Removed the rear bedroom Fantastic Fan vent , which was old, cracked and leaking, and will replace it with a better one..
Stripped the roof of weathered aluminum, and junk with an Eastwood SCT grinder...
Then 3 coats of white roof paint.
This week I hope to get one more coat on, then remove the rear AC unit and clean and paint that section before replacing it with a new gasket.
The temp drop between painted and unpainted, was instant, and noticable, even on a cloudy day with an almost 5f drop between painted, and unpainted sections read with an IR Thermometer inside.
