picts of your in-floor heat set ups.
xyster101
Upstate NY
5 years ago when I built my 1200 sq/ft shop I put in PEX Oxygen barrier pex in the floor. Finally I hooked up a heat source. Thanks to here for the ideas and help.
I found ISO old roof foam on CL. I got a boat load for cheap. R-30 in the walls and R-49 in the ceiling. This is more then a house requires in my area.
I went with a tankless Takagi unit that was $500 on Amazon. Fittings and other bits were $600.
I have 4 loops of 250 ft that runs off 1 circulator pump. I did the "pump away" set up as recommended here. I borrowed a IR camera for an Iphone from a friend. Really neat to see the tubes in the floor.
Tucked away in the back corner. Installed Jan 2019 and has been running about 3 weeks. Really nice to have a warm floor.
I also made a video describing the set up. Basically all I learned from hours of research on here.
:beer:
Please take a look.
bams50
Central NY State
Very interesting. I am in Central New York, and just bought the land where I want to build, just outside of the city of Oswego. I am hoping this year to build my new shop, approximately 60 x 120. Ideally I wanted to go with in floor heating. I haven’t really done much research yet. I’ll have to determine if the initial investment justifies the upfront cost. Thank you for making the video, I did watch it. Since mine will be automotive repair, I am thinking of a waste of oil boiler. Also will be researching wind and solar. Obviously the goal is to make my overall utilities as low as possible. How far away from me are you?
jaycoflyer
Have learned a great deal from reading all your posts. Had my system installed recently but not sure it's "dialed in" performance-wise. Hoping a few of you will be able to compare notes with me. I'm using LP tankless heater capable of 20K-125K BTU/h. Have 4 loops of 1/2 pex oxygen-barrier nearly centered in 5" slab (total of 1200 sq ft) and 2" R-10 foam underneath and along sides. Currently, my inlet temp is about 125. Outlet temp is about 65, so about a 60 degree drop. Flow according to manifold guage is about .25 GPM per loop. I keep thermostat set at 55. I believe the flow rate is quite low and the temp drop very high, thus system runs a LOT! TACO-007e is my circulator just ahead of inlet manifold.
Will appreciate any folks out there willing to share numbers on similar systems.
I *think* that increasing my flow (and reducing the temp drop) will significantly improve my efficiency.
Thanks for any help!!
kj_mustang
Harrisonburg, VA
Flow rate probably should be closer to .4-.5 per loop. Do you use Loop Calc or anything to design the system? The design would have told you the flow rate needed.
PWC Repair
Arkansas
You could literally pay for all your upfront costs in a couple winters......
Closed loop radiant floor with waste oil heater in it's own room outside. A couple zones for water to air fan coil blowers. AND.......as a bonus there would be no open ignition source from the heat!!
jaycoflyer
LoopCAD was used. Flow target is about 1 GPM for each loop. Delta T is supposed to be 20. My installer insisted on using 100% glycol which I think is a big mistake. From what I read, this lowers system performance (heat transfer) and makes circulators work harder likely reducing flow. Thoughts?
koditten
Midland, Michigan
That makes no sense to use 100% glycol.
Strait water gives you the best heat transfer. The glycol is only there to prevent freeze ups as well as the little bit of inhibitor that is present as well.
stingry
Western Nebraska
I looked at the pump specs for your pump. Two things stood out. First, the mfg says to use no more than 50% glycol. Second, your pump will not operate well over 10 ft of head loss. I’m guessing you have well over that between the piping and the tankless heater. You need to calculate your total head loss and size your pump to that.
Denwood
Thunder Bay, Ontario, Canada
:beer:
Please take a look.
Nicely done. I like the relative simplicity of the setup..with all the essentials covered. You also managed an excellent budget! I've learned that when it comes to efficiency, building envelope comes first. You did great by re-tasking all that insulation.
Check your door seals! Our usage dropped 80% on the slab after replacing the old top/side seals with new dual blade versions. Thread here: https://www.garagejournal.com/forum/showthread.php?t=414538
This graphic says it all. It shows data from one of our four radiant zones via the Ecobee3 stat running the show in our loading bay. It's about 16x32 with 20ft ceilings. The overhead door is 10x14 or so, 2.5" thick with a foam core.
Matt723
Very nice setup xyster101!
Do you have a pump controller? How is it hooked into the system?
Thanks!
xyster101
Upstate NY
Not sure what you mean by a pump controller. I just have a 120 volt thermostat ($20) that turns on the circulator pump when the air temp reaches 50 degrees. Once the tankless heater detects water movement it automatically turns on to heat the water.
I have 4 loops of 250'. Temperature in the floor is 104 and temp out is ~60 with 1.8 gpm flow rate.
iowa4x4dieselman
42X48 Shop/Garage in progress. I installed the stegowrap then the crete heat panels. I built a pex uncoiler and then I placed the pex into the panels and plumbed it to the manifolds. I marked out where I will be placing 2 2-post lifts and ran the pex around the area and installed the wire matt on 2.5" chairs. I had the floor poured in December 2017. I am currently waiting for the weather to warm up so I can lay down ArmorClad Epoxy with fleck and military grade top coat. I will install the high efficiency triangle tube boiler this summer and finish off the heating system as well as insulation and steel wall liner panels.
Sean
How did you make your tubing un coiler? BTW that shed looks BA! :bowdown:
Fastback
Indy
Re: picts of your in floor heat set ups.
Thanks for the info very helpful!
Any issues or updates with the system ?
Thank you
John
Thanks.
It's been on for years now with no issue. In fact other than checking the air pressure in the tank once a year I never touch it, I keep the thermostat set at about 52º and it kicks on a lot less than if I try to maintain 72. But, since I don't have any paint projects going on 52º seems warm when it's 10º outside. (But, somehow 52º seems chilly in October :) ) The thing about electricity is, the more you buy the cheaper it gets, so at some point you are better off keeping it warmer and going for that magical break even point because you are buying in bulk so to speak.
Mancino
Upstate NY
Finally got some funds for my boiler install! Still a work in progress, but its getting there.
papp101
thanks for posting a Pic, Mancino! I appreciate your input on my other thread. :) Nice setup!
Verado1250
I have a question for anyone who can answer..I have a hydronic system also, with a propane micro condensing boiler (Hydrosmart). The directions when I installed it said the intake pipe (air) does not have to be routed outside. Therefore, to eliminate the extra hole in the side of the shop, I decided not to for the first winter and just leave it uncapped inside. However, on most of the pic's in this thread, I see the intake and the exhaust pipe being routed outside. I know my intake pipe is taking heat out of the room, but, with it being outside, it would be taking cold air into the unit. What is the rationale here? Should I run the intake pipe outside? I won't install one of those combined fittings, as the instructions does not have them listed as an option. Thanks.
tricountytrail
Pendelton, NY
Just installing mine now.
Couple of Questions Low water cutoff sensor, I was told to install in a tee at top of boiler right before pressure relief valve for boiler loop.
where is best place to install circulator and air separator
Pressure relief on domestic side where is best place for relief and can air separator and expansion tank be any where?
And if I am only running my boiler(for radiant floor heat only) axp 120 degrees max can I not use the mixing valve, only two sinks and shower very minimal use.
https://www.garagejournal.com/forum/attachment.php?attachmentid=928507&stc=1&d=1568825715
https://www.garagejournal.com/forum/attachment.php?attachmentid=928508&stc=1&d=1568825715
papp101
Here's mine!
24*26 detached garage.
2" eps foam underneath, R22 walls and roof.
Navien NCB-180e
Building load is only 30k loss, but the boiler can go down to 14k btu, so it works.
Sent from my Pixel 2 using The Garage Journal mobile app
papp101
Nice setup, where did you buy the boiler from? Might look into one of these since my building is around the same size.
Thanks! Got a deal on Craigslist. $1300!
What are do you live in?
Sent from my Pixel 2 using Tapatalk
durk_2007
GB Kansas
I have done quite a bit of research on radiant And have hydronic baseboard system in my house. I'm building a new shop and one ? I have that I can't find an answer to is besides a larger manifold is there any downside to shorter loops? Thinking 75-100 feet each 6 loops. 500sq ft pour.
My thought is less temp change across floor, lower deltaT, and less pressure/head
bodean123
Crowsnest pass
Can any comment on this setup?
We are looking at purchasing a new home, it consists on a 2800sqft shop with 1000sqft attached residential. The entire slab is heated with radiant floor heating. We do plan to have a home inspection done, but from past experience they generally just check to make sure everything is in working order.
PWC Repair
Arkansas
Finally getting my system together now that it's already cold:bounce:. I still have to hang my fan coil and finish a bunch of soldering. Been quite a while since I sweated any fittings but it came back to me and I have high hopes that these will all be leak free when I pressure test. Then I'll shove some contactors and stuff in that repurposed meter box and try to make it look acceptable.
tricountytrail
Pendelton, NY
PWC Repair
Arkansas
Ready for the winter Working Great!!!
Nice!! I've used those fittings with the solder already inside and LOVED how easy they were! Wish they still had them around here but even the regular copper selection is getting slim. I guess everybody uses pex and sharkbites.
I hope to have mine going before long. I spent 4 hours Sunday sweating fittings and 4 hours today building my fan coil cabinet so I can hang it.
z28toz06
Connecticut
Help! drained system this summer and refilled it. Tried purging air from top bleeder but I don't seem to be getting hot water. heater sounds like its cooking but im not getting hot water. it was working fine when I shut it down. simple closed system. trying to post pix but its looking for URL.
seanc_mt
Upload the pictures to imgur or flickr then they will give you the url to link it.
