Amazon Hyperikon 5000 LED T8 bulbs
3rdgendslmech
Maryland
Anybody have any personal experience with these. They've got great reviews and have been thinking about replacing the old fluorescent tubes.
thammel
Maryland
Yes, I bought them. I love them. I got single ended ones and frosted. I left my ballasts and all wiring in place in case for some reason anyone wanted to go back to fluorescent tubes.
Tom
Zaxxn
CT, USA / Germany
Can't say much about these particular bulbs, but I bought a lot of Hyperikon bulbs and lights over the years and was never disappointed. Definitely a good step up from the regular Chinese eBay items.
--Zax
threeputt
Next to a very busy 4 lane
Bought some for a friends shop. He don't buy over the internet so I did it for him. He got the 8 foot single pin. He removed his ballasts and the rest was a piece of cake. Loves them. Came with sagging clips and new tombstones.
bobabuee
HAZLETON, PA
there awesome i replaced t12 8ft 2 bulb 4 fixtures with them about 2 yrs i was on the fence about switching i have 10ft x 20ft office with 8ft ceilings i got clear lenses. i have sign shop so colors need to look good my god my office is so bright i cant look up without being blinded lol. i had one bad out of the box messaged them had a new one in 2 days.
you can get a better deal ordering direct from them you even make offer price warranty
is awsome no question asked you dont have to send anything back to them.
Phantomd
Near Boulder CO
I've installed and re-wired about 40 fixtures with these bulbs. I like the 40,000k color better but they have been fantastic. rewiring is super easy and worth the power savings. I measured a 40% reduction in power usage from the 32w bulbs.
Couple things of note, they don't rotate, and they point down, fluorescent bulbs point in all directions so it's a bit different.
Phantomd
Near Boulder CO
Horses, color is personal preference. Hyperikon comes in 30k, 40k, & 50k kelvin color temperatures. 30k kelvin is very "warm" and can seem very yellow, 50k is very "cool" and is sometimes referred to as bluish. Home Depot usually has decent displays with examples of the color differences.
Rogue1987
Missouri
They're awesome - I've installed a few cases in the last couple years and have yet to have a failure.
dogdog
they still work after about 3 years now... maybe 2... but they are just my kitchen lights....
Specracer
I have done around 10 fixtures so far. Ripped out the ballasts, and never looked back. I solved the "sagging" situation with a long white wire tie. Instant on (no warm up). Assuming its not a "high bay" application, be sure to get the frosted for better light dispersion. I liked this solution so much, when adding more fixtures, I bought new fluorescent fixtures, and pulled out the ballasts, and used the LED bulbs.
Slednut
Washington state
I was going to need 28 bulbs to convert, I ordered 4 and converted one fixture. I liked it so I then ordered the 24 pack and did the rest. Have had them for 2 years now, really nice.
HotrodHR
North Alabama
I replaced all my 4 foot tubes with LEDs from lowes or Home Depot...
I'm confused, these are sold as direct replacements, why would you want to remove/bypass the ballast etc? I know several years ago you had to retrofit fluorescent lights in order to use the leds but not today. Are there any benefits to doing this?
Dagny
Northern Wi.
You have 120 volts then you step it up with a ballast then down with whatever they use in the bulbs to lower it then to DC to light up a diode. Things are just a little simpler if you remove the ballast.
Dagny
Northern Wi.
Also be careful if you have very high ceilings and your fixtures have reflectors behind the bulbs they will serve no purpose with the led bulbs.
cybrdyke
USA
It's a choice. They make one style that runs on the ballast and another that doesn't use the ballast.
If your ballasts are a compatible type, and are in good condition, then there's no reason to bypass them. It will cost you about 2 watts more per tube. If your ballasts are old, worn out, or of the wrong type, then it will likely be best to just bypass them.
CD
Phantomd
Near Boulder CO
I would bypass the ballasts simply because it's another point of failure for the light fixture.
LEDs are supposed to have an extremely long life as long as their driver circuitry lasts. I dont want to touch the fixture again if I don't have to. Not to mention the additional power draw from the ballast.
rewiring is extremely easy, I use the push in connectors since its such a low load per fixture.
BD1
north side
The Costco LED 4' shop lights have great reviews, if that works for you. I bought a bunch for $20.00 each.
