I want a longer pry bar ...
ajchien
Los Angeles, stuck on the 60 freeway.
Long story short - after getting my ball joint back in place, I want a longer pry bar. My longest is a craftsman 36”. I’m looking at mayhew’s 48” and 58” bars.
Does anyone have these or can give me opinions on which length they’ve found more useful?
Any other brands for a 48”+ bar that you guys would suggest I’ll also look into.
ChrisLS8
Are you using it to seperate the joints? If so there are far better tools for that
A
ajchien
I needed to pull the control arm down to get the ball joint/knuckle back in the lower control arm. I was using my jack to push up on the knuckle for a while, and my axle kept popping out. Yes, I’m a diy weekender working in a garage on the floor with no lift.
Professional Tool User
BC
The only other option I know of are Snap on. Mac might have the longest sizes as the shaft is probably from the same source as Mayhew given the ll and kk markings. I've got the shorter Mayhew dominator sizes and I love them.
Zewnten
Co-worker has the Mayhew rebranded as Cornwell, seems to be holding up fine. I have a Snap-on in a similar length. But I think I like the bit of curve the Mayhew has more than my Snap-on's angle
RKA
Mayhew would be my first stop, snap on second. But sometimes the longer ones just aren’t helpful for me. But I’m on the ground working under a car not a truck. Just not enough clearance to work a 4ft bar.
You probably already did this, but the opposite tire is off the ground right? If there is a swaybar it will twist and load parts of the side you’re struggling with if one end is in the air and the other is on the ground.
Ign
Butte Peak ND
Fedwrench
Valley of the sun
Just don't get hung up on length and forget about the bar stock thickness. I'd look at dominator in 42-48 lengths with the thickest shaft.
kctyphoon
Jersey/Staten Island
I had a hell of a time when i replaced every ball joint and bushing in the entire front end of my old f350... my twin beam front suspension was encouraged with a chain hoist and a sling.. it was like having an extra hand to pull things back where they needed to be.
619DioFan
San Diego , Ca.
I have the 48'' mayhew bar. it is excellent. if I need more leverage I also have a 60'' slate bar the is designated for mechanical type work.
gatlibs
N/A
I've been pleased with my Lang branded ones. I have one Mayhew in a screw driver tip. They seem to be the same quality and design, possibly same manufacture. Nevermind, they only go to 3'.
lilredex
Toronto
My go to bar, whenever anything heavy needs moving. A pry bar "borrowed" from the CNR about a hundred years ago and passed down to me. My grandfather worked at CNR.
It is the tool to pry down control arms.
Mr_B
Reading
any long bar or thick wall pipe will do.
Main trick is a short length of chain to put round arm and join with a bolt or u shackle to create easy secure way put load on the bar .
I buy a long prybar be sure it not to bendy or you run out of room as bar flexing and hitting ground before arm moved enough .
with right working practice of vehicle axle lifting and suspension dismantling you shouldn't need go silly prying them .
ku17
On a tangential note, how does everyone store pry bars longer than 36”? The super long ones just don’t seem to fit anywhere in a garage
cowboy73
southern Indiana
If you have space under the workbench or if you don't move your tool chest around, you could lay it on the floor and slide it under. Paint it a bright color so it can be seen and of course remember where you put it.
kb1982
Kentucky
If you need a big prybar, the big Mayhew Dominators are nice. I use the same bars (company provided) at work, so i had no doubts about about what brand to go with. Even the mold setup crew cant break them, that says alot.
Sent from my LML713DL using Tapatalk
Elvisidal
Australia
This
Go to the hardware store and go,to where they have the shovels and such.
They have long pick and breaker bars there
My advice too but the drawback here is the size of the prying end is often too large
Eyebolt on a wall stud
iWrench
USA
A tool I found works wonders on pulling control arms down with a prybar is OTC tool #6007. It's like $20 on Amazon. Very simple tool but provides a solid way to pry on virtually any lower control arm.
