And the steel ones are very thin. There are lots of videos on YouTube of guys making crucibles from fire extinguishers, but for the most part they are short lived.I have made a few things on my 3D mill, the printer only uses PLA and ABS plastic, they don't vaporize like foam. However I cut my foam with a hot wire, knife, and sandpaper to make most everything.Andy: the guys making commercials could learn a thing from you and sell just about anything by showing how much a guy that is well into his 6th decade can get done in a day (ANY DAY).
I'm not sure how hard it is to pop out all your 3D foam molds, but I bet your little computer and 3D printer are working almost as hard as you are.
keep up the great work and always good to see what a guy with a few tools and a lot of energy can get done in a day.
can you really cut an old fire extinguisher in half and make a decent new (slightly used) crucible so you can shelve your slightly used one that you made as your first one?
hope you have some fun and get something done today as i'm hoping to do the same.
i'm not sure if Hershey is scratching her back or just happy, but our daughter's dog does something similar when he's visiting while they are out of the country. the only thing is our cat (CLEO) doesn't like him in her domain so she lays on his bed when he's gone to let him know it's her house.
cheers
Andy, the fire extinguisher may not make a crucible, but it can be a source of CO2 for curing the mold. I have seen more than one "home shop" using them. Though I think a proper tank of CO2 might be cheaper in the long run.
Sent from my SM-G930T using Tapatalk
Boy if I could figure out how to capture it and send it your way I have 46,000 little CO2 factories in the barn that could supply you with more than you'd ever need![]()
I appreciate the kind words.
The problem with threading the aluminum is that the angle changes as the arms move. I thought about threading one side with a button head on a bolt pushing on the other side (it could slide) but I couldn't see an easy way to keep it in contact, to keep the clamp from closing on it's own.
The nuclear fire will kill us all first.Not a reliable source. When the Green New Deal takes over and we're all walking between home and work any production of methane or CO2 will have to be enclosed (you have a start) and all those unnatural vapors must be captured and sequestered.
Good news is inspectors can't fly between locations so we'll have to rely on neighborhood snitches doing their patriotic duty. We can form groups of workers for the common good...
Gotcha - now it makes sense to me. I didn't understand how the hinge nuts worked. Thanks for photos and explanation!
The assembled clamp looks really nice, and the threaded bolts should do the trick for adjusting it. I'm also constantly amazed at how long all the little steps take.
After each household cuts a check for ~$600K for the same patriotic duty.
Came out so
Wow, that latest Burner head casting looks AMAZING, even in its raw un-machined form, I wish I had a use for one just to add another AWM piece to my collection of Broom and aluminum hammer
Andy
I have to correct your last sentence:
"Came out so" GREAT!
Great job!![]()
Andy: it looks like your new idea (or idea you copied or got from one of your casting friends) worked great!!
so since you are planning on making a new crucible any plans to make it bigger and maybe a bigger forge/furnace or is that size about right for you?
snowing here now so officially weird weather season cause supposed to be mid 40's and low 50's tomorrow.
have a great day and i'm pretty sure i will too.
cheers
just checking in to see what fine things you have have been casting lately
My plans have just changed again and it looks like it will be a couple of weeks before I can come out but for sure I'm coming soon
Don
Andy I am just catching up on your thread.
Great work as always, learning sharing all the time.![]()
Andy, let me know when Don is coming out to your place so I can go to his and safety check the Vette. Shhh mums the word ok.
Pretty snappy casting for a cow farmer. You are looking good, Andy. Keep it up.
That is a lot of copper! Big job chopping it up and flattening it all to fit in a crucible. Great job for a flypress methinks.![]()
Good to see how that crucible stood up. Mine will last a long time if that one survived that many charges. The long reach clamp should work wonders with those feet on it. You can get replacement pads for those Stanley quick clamps that would be easy to make clamp feet for! Otherwise some HDPE furniture ‘feet’ stuck to the alloy would be a great alternative. Knobs like that is another good reason why I want to cast my own stuff.![]()
The new sprue looks like it worked a treat.
Should be easy to add some pins to help hold the pattern parts together. Alternatively use a splitting plate which is just a sheet of metal with a hole in it to hold the full sprue pattern and removed when flipped over. The often use them for patterns that can’t be split, already have a split line it can index on or holds an asymmetric core mold. Moulding table would need clearance too but even that can be a sheet of styrofoam with a hole in it or something. Just ideas...![]()
Andy
Well done, you are definitely a great student of art and science of continuous improvement. The open riser and large gate was a great idea.
Those calves are cute and curious but now after seeing the photo, I think having an Italian veal Parmesan will be on hold for a while (but not for too long, I like my red meat)
Great job on fixing the door closure arm as well![]()
ANDY: Nice repair on the door!!
great information on the different style of getting your melted metal into it's desired spots. something you learned from your other forging friends or is this using what they've said with your own knowledge?
your little calves look great and do you name any of them or just call them hamburger or mignon or ??
Andy, great work all round, I'm learning plenty , thanks, about stuff I never knew I needed to know about. I have some ali I just need to find a fire, although being English, I will have to put the kettle on it first.
I have all ten fingers, but I'm not very good at woodwork,
Have a good week.
Steve
Ps. I have a Briton 121ce if you want it.![]()
I have a few in the attic but nothing matched.Nice job on the door!
Agreed on next weakest (my guess: where it connects to the door {yikes}).
I'm impressed with the concepts you are testing. Also wholly under-educated on the bifilm concept that I've added it to my list of things to study up on. (Yes, I have a list for personal development in a drive for continuous improvement) Unfortunately my list is slightly prioritised towards work since that is sometimes urgent. Luckily there isn't many of those right now.
The idea of ramming a casting basin+sprue form into the sand seems almost perfect in it's practical simplicity. At least compared to curing one using waterglass. Is that still in an upper flask? Seems like a tin can or section of box section tubing would suffice well for that.
Keep playing, I'm learning lots!
I also joined the homefoundry forum since it appears friendlier than alloyavenue. I like having access to advice and information but the elitist snobbery of some forums inhibits my contribution.
Plus I wanted to see more photos. Especially the stuff you are not posting here.
PS. You guys make wood work sound like sheet metal work - apparently more likely to have you needing to count to ten using your toes instead of fingers.![]()
As Guster says....
Impressed
I love what you are doing Andy.
And of course, not only are we learning random stuff from you, but you are keeping your brain both active and amused in what could be retirement.
Like the term or not, there's a lot of "continuous improvement" going on here.
Not that your castings were ever lacking in quality.
Great work Andy.
[emoji106]
Sent from my SM-G950F using The Garage Journal mobile app
(If you don't believe me, ask your wife)Andy said: I just keep seeing more little calves in the pasture. Makes me wonder, where do they come from?
Well Andy, I could tell you but it would be a lot of bull.
Laughing here.
Retirement for many is sitting in a corner waiting to die. Not the morbid way but just not doing all the good stuff.
Your retirement is just perfect.
