Colorado Basement Floors
benwah
Crested Butte, Colorado
Hi Everyone! I have been gone for some time but I just wanted to share some pics of a double broadcast quartz floor I just completed. This is a full house remodel and the walls aren't even painted yet. There will be baseboard and door jambs with tile leading to these rooms keep in mind. Sorry I didn't take a lot of great pics.
There are 3 rooms in the basement that were coated. A mechanical room with a concrete floor, and 2 storage rooms with 3-4" gypcrete floors due to in floor heating. Ground everything down including the gypcrete, routed all cracks, vac'd; Filled saw cuts, missing gypcrete chunks, and cracks with epoxy joint filler then primed with APF vapor solve primer.
Unfortunately we had a nasty expansion joint that we couldn't coat, so we cut around it and prettied it up a bit at the end.
20190307_125127.jpg20190307_125132.jpg20190307_125140.jpg20190307_125145.jpg20190307_125147.jpg
Next day came in and scuff sanded the floor, vac'd, solvent wiped then laid down APF vapor solve 100 @ 20 mils and broadcast 275 LB of quartz.
very quick rolling video
Next day came in swept, scraped, vac'd then laid down APF 450 @ 20 mils and broadcast another 300 LB of quartz.
After that cured overnight came in and repeated the same cleanup process then laid down APF 100% solids polyurea 5100 at around 16 mils.
Copymutt
Colorado
Nice job.
I’m gonna play devils advocate here. Have you done testing for radon?
It’s free from extension service.
Armorpoxy
Congrats! Quartz floors are great, but often too pricey for most budgets. We love them and sell lots to our commercial customers.
FullMetalTrousers
Texas
I used APF 100 first, and then APF 450 but my color was only slate, so it wasn't terribly difficult. This looks excellent. I think the APF450 product is a good one.
benwah
I agree their 450 is decent, and easy to work with. Have used it for years with no issues. That's about the only product we use from APF anymore.
I had a bad experience with their cove resin after applying it to about 600 linear feet, don't use them much anymore after that.
