Where did you get the gauges? Stainless body? looks good.
They’re just amazon cheapies, about $25 each. One of them had a really large air bubble in the gauge. I drained and re-filled with mineral oil.
I've always wondered with these lifts, do you just lift on the rocker panels/floor pan, or do you need something to lift at the pinch weld?on my flex, the doors wrap under the vehicle, so I'm not sure how one would work
I wonder if the drill bit is wearing out making the hole a bit smaller so you have a tough time driving it in.
You didn't buy the bit from HF did you?
Hydraulic and air pressure gauges are drilled and mounted in the console face panel.
What kind/make of hose did you use to connect your hydraulic pressure gauge to the pump? Got some pictures of that part? Thanks!
What does the fuse do? Is it just an orifice so when a hose burst it will drop slowly?
