Mechanical floor jack restoration
don long
southern california
I picked up this small floor jack one day in my travels and it has been sitting in the shop waiting for some love.
I was cleaning up the shop and the jack was in the way but it called out for some help. It has no handle and the knee is stuck up in the air
3 by don long, on Flickr
1 by don long, on Flickr
I put it up on the work bench and took a hundred pictures of the jack
2 by don long, on Flickr
Then I sprayed all the jack joints, nuts and shafts with rust off to loosen things up and walked away for a couple of days while I finished up another small project.
When I got back to it, things went pretty well as I started taking the jack apart.
I took more pictures as I removed each nut and washer documenting each piece (my memory is too short to not have back up)
I finally have the jack totally apart
IMG_0784 by don long, on Flickr
Some of the issues I've run into is where the connecting shafts were pinged over to hold them in place
2019-03-14 15.52.38 by don long, on Flickr
I was lucky on this one, I only had to grind off one end and pushed the shaft out the other end. you can see the lip on the unground end.
IMG_0751 by don long, on Flickr
Offcenter12
Seattle
Looking forward to this resto. You must have the coolest vintage garage on the planet. I can see some cat with a pack of non-filter Camels rolled up in his T shirt sleeve and a DA changing a tire on a '36 Ford with this in its heyday. :thumbup:
whateg01
doo dah, kansas, usa
For future reference, sometimes, you can get a carbide burr in there and grind away the lip that is formed by the peening. That allows the length to be left almost the same so when you reassemble it, you can just peen the end again. Depends on how authentic you want the restoration to be, of course. If that's not a consideration, a new pin turned for snap rings is an easy and clean way to reassemble it.
Dave
D
don long
southern california
Thanks Offcenter
I can picture your vision and I have the 37 Zephyr that goes with your vision
I think this jack will show well when finished
Dave
Thanks for the tip Dave
This will be a custom resto like most of what I do
D
don long
southern california
I made a little headway on the jack today
All the pieces have been sand blasted or hit with the wire wheel
2019-04-03 08.07.18 by don long, on Flickr
I straightened the sheetmetal cover that goes on the knee of the jack and started grinding and cleaning up the shoe so they can go out to be chromed.
I also cleaned up the main gear and smoothed the teeth so the chrome will be smooth when it comes back
These are the pieces that will go to the chrome shop next week after a lot more work
2019-04-03 08.08.59 by don long, on Flickr
And just for fun I spun one of the axles in the lathe and ran the pistol grip sander against it to see if it would clean up
2019-04-03 08.36.35 by don long, on Flickr
I like the results well enough to spin the other axle and the lower spacer
to the same shine tomorrow
I think this project is taking shape
Stuart in MN
Minneapolis
Do you have a regular plating shop you use for your projects? I can imagine them rolling their eyes whenever you walk in the front door..."What kind of weird stuff is Don bringing in this time?" :)
D
don long
southern california
Nice project, keep the updates coming!
Thanks ndnchf
I'm all over this project so the pic.s will be coming
Yes Stuart
The same guy that Chip Foose uses for his cars.
He is a long time friend from my bodyshop days
D
don long
southern california
I found some time to work on the jack today.
After looking at my pictures for a while I started the reassembly process by welding the spacer studs back onto a leg of the jack Knee and grinding them smooth
IMG_0989 by don long, on Flickr
I filled all the rust pits with body filler and hung all the pieces in the booth for primer
IMG_0990 by don long, on Flickr
I mixed up a batch of primer and blasted all the parts
IMG_0997 by don long, on Flickr
I turned my attention to the parts that were going to the chrome shop and started smoothing them out. I got a little carried away with the gear and decided that it would be a hard job to chrome so I just polished up the teeth a bit more I liked the result. next I grabbed a wheel and mounted it in the lathe. I spun it and ground the pits out of it. I decided that I could just polish them and save a ton of time and several $$$ so I gave it a whirl.
I like the results . 45 minutes and a few pieces of sand paper and the wheel is shinny. So I grabbed the splash shield and went to work on it and here is the results of my shine efforts
IMG_0994 by don long, on Flickr
IMG_0996 by don long, on Flickr
I think they turned out ok for this old jack.
I'm not sure what i'm going to do with the butte plate yet.
Offcenter12
Seattle
As always, stellar work! Reminds me of a time when items were pretty much designed to do only one thing, but do it well, which is probably why a lot of it is still around. Your Zephyr is a beauty! This floor jack ought to pair up nicely with the tire changer you did.
John
MushCreek
Upstate South Carolina
I have the twin to that jack. Any idea what make it is? I also can't figure out how you lower it. It goes up, but I haven't figured out a mechanism to get it to come down under control.
whateg01
It's hard to tell in the pictures, but on an old jack like that, I would expect it to lower similar to how a come-along can be let out slowly. There must be a pawl that holds it up when you get another bite going up, so is there something that releases that pawl?
Dave
Sevenhills1952
Virginia
I have that jack my Dad (r.i.p.) got in the 50s (used). Turn handle cw and it raises one tooth at a time, ccw it lowers one at a time.
Sent from my SM-S320VL using Tapatalk
D
don long
southern california
John
Thanks John
I'm thinking to paint it red and black and letter it with the Signal gas logo and put it with the gas catty and battery charger in front of the gas station
D
don long
southern california
I made some time to work on the jack today.
I have all the pieces primed and needed to put the jack knee together to drill and tap some holes to hold the polished skirt in place. It was welded before but I couldn't reweld without destroying the polished finish.
IMG_1023 by don long, on Flickr
IMG_1024 by don long, on Flickr
After drilling the holes I took the jack back apart and painted the knee and drive gear red
IMG_1025 by don long, on Flickr
I'm happy with the way this project is coming together
I think it will be a keeper
D
don long
southern california
An update on the jack progress.
I managed to get the knee parts painted and then welded all together.
Today I painted the welded panel and the rest of the small parts red.
I painted the 2 body sides black last week after grinding all the rusted pits out of the panels. Today I managed to get them color sanded
2019-04-16 16.01.41 by don long, on Flickr
Then buffed up to a high shine
2019-04-16 16.12.42 by don long, on Flickr
2019-04-16 16.13.45 by don long, on Flickr
I'll be putting this jack together in a couple of days.
I'm hoping that the polished steel pieces will pop against the black and red colors
D
don long
southern california
Wow - vive la différence!
Thank you J.C.
The jack came with out a handle so I'm having to build one with a nut driver in the bottom of it. I welded an old socket into the end of the pipe tonight but had no way to keep the handle attached to the jack so it's back to the drawing board in the morning
D
don long
southern california
The wheels look nice.
This is going into the show case right?
Thanks AK
It takes me about an hour to polish each wheel I've done 2 of them so far.
The jack will sit infront of the Signal Gas Station when it's completed.
I did get the handle made today.
I made it out of black pipe. I welded a socket in the end of the pipe to turn the directional nut on the jack. Then I screwed a pipe cap on the other end of the pipe and turned it smooth. The pipe is now ready for paint
30 by don long, on Flickr
31 by don long, on Flickr
33 by don long, on Flickr
D
don long
southern california
You do good work!
Thank You Dreamer
It's nice to have it in the garage on display
You can add master polisher to your resume now :bowdown: :bowdown:
Good idea Bears fan
But who would I show my resume to??
Absolutely gorgeous Don! I bet it works really nicely too.
Thanks ClappedOutBport
It does work smoothly and quietly now. It was a real mess when I first got it
Here is where I've placed it for now.
It is scheduled for the pin striper next week
2019-04-23 15.13.16 by don long, on Flickr
lukedwag
Thank You Dreamer
Good idea Bears fan
I love your old school tire equipment. My dad and I still change a lot of tires by hand on the farm. It's kinda like splitting wood by hand. A real labor of love.
Sent from my Pixel 2 using The Garage Journal mobile app
gpw_42
NC Sandhills, USA
Don, it's a great outcome, especially comparing before/after pics, well done!
Do you use wax or some other product to protect the polished surfaces from oxidation? If so, what?
