Armorpoxy floor install and long term results.
Mpower5266
Newnan, GA
I installed my Armorclad kit this past weekend and I figured I would make a thread about the install and then update it as I use the garage. I am not affiliated with Armorpoxy in anyway but they have been very helpful in the process so I wanted to do a review.
The garage is approximately 560 sq, a 20x24 main parking area and smaller 8x11 area that joins to the basement. Its an addition on my house so its a fresh pour, probably 5 months old and no cars (technically) have been parked on it.
Untitled by mpower5266, on Flickr
I opened the packages, and noticed I did not receive instructions, but they were easily accessible on Armorpoxy's web site so I printed them off. I started with a good deep clean of the floors and scraped up any drywall mud or mortar left by the workers.
Then hosed it down and applied the acid etch with a push broom. I didnt notice much foaming or really anything happening but the floor was really clean.
After that I pushed all the water I could out of the garage and let it dry out.
This little guy came in very handy blowing the water out and dusting in between coats, I highly recommend some sort of blower if you are doing your floor.
I wanted to make sure it was dry so I ran 2 dehumidifiers for about 30 hours, it was very dry after that.
Then the point of no return, we mixed up the primer and rolled it out. I mixed it in a new 5 gal bucket and dipped the roller in rather than dumping it out on the floor. I didnt trust myself to not spill it everywhere. :lol_hitti
It went on smooth and covered well.
I would highly recommend a mask at this stage, maybe I'm a wuss but I had a pretty bad headache that night. Anyway, followed the instructions and let it dry for 24 or so hours and put down the epoxy.
I mixed it in a 2:1 ratio but portioned it out 4:2 and did the garage in stages. My dad poured and rolled while I used the spiked shoes to spread the flakes. I wanted the flakes to have the look of the BMW M Colors and I was not disappointed.
I had a few areas where the flakes were a little heavy but over all it came out awesome.
I even got a really nice tape line and I **** at taping.
Let that dry over night and put down their military top coat with about 3/4 of the supplied can of grit additive. I was very happy with the results but again highly recommend using a mask, this was the worst smelling stuff out of the three.
All and all I am happy with the results and impressed with the ease of install.
I will update this in the future if it wears or if I notice anything interesting.
Toomanytools?
Washington
Nice job , to bad you aren't closer you could come do my shop 1000sq, Armorpoxy waiting in the can. I need to find some time before our temps hit 100 degrees.
thammel
Maryland
I did my armorpoxy floor last Sept and it looks great. Very strong! I definitely recommend the military topcoat and the antislip additive; it is not at all abrasive or a problem.
Tom
Mpower5266
Newnan, GA
Almost a year in and the floor still looks great.
IMG_6809 by Nick Wood, on Flickr
IMG_6829 by Nick Wood, on Flickr
We also put down the same epoxy in my dads 30x40 shop. We recently had about 15 gallons of probably 20 year old gas still during a fuel tank replacement and the floor still looks great.
Hivolts
Nice work and looks fantastic.
So, armorpoxy doesn't require grinding concrete? Just acid clean before install?
Thanks
CJseven
Southeast Missouri
I had to run a 7” hand grinder over most of mine very lightly to knock off places were they splattered concrete on the slab when pouring the apron and a few spots that looked like they had cement on there boots and stepped across the slab, it for the most part acid etching is all that they require after HOURS of cleaning and cleaning. :) I have only had mine done since oct 18 , but so far it’s been what I was hoping for. IMG_0979.jpg
Mpower5266
Newnan, GA
Thanks
Mine was a new slab so I just did the acid etch and primer. If it were an older slab you may have to grind.
