Most durable outdoor finish
6PTsocket
I have a bunch of fake, plastic 1/2 barrels that we keep on the deck and plant veggies in, mostly tomatoes. The small HF movers dollies are perfect for moving them around and at frequently $7.99, there is nothing at the garden center that is even close. They are some unknown wood with rug stapled on the end pieces. They were never intended for outdoor use, the rugs soak up water and and they rot in a couple of seasons. I finally got around to doing it right and bought a bunch the other day. I will remove the rug and the question is what to coat them with. Paint peals, Opaque stain lasts longer than transparant or semi transparant but is closer to paint and also peals. The clearer stuff can be recoated but doesn't last that long. These are not for show and any tan or brown or natural color will do. The casters have done OK, left outside. What is the most bullet proof finish. The wood is not pressure treated. I considered building from scratch using 5/4 pressure treated and reusing casters. That is plan B if I cannot preserve the new ones. There is probably some urethane paint out there but it probably would be cheaper to replace the dollies a few times. Thanks.
astroracer
Mid_Michigan
Plan B, don't waste your time and money trying to paint them... There is no coating on this earth that is more powerful then Mother Nature... Sun, wind and rain WILL prevail!
The other option would be to buy the poly carts.
fasteddie
As they rot out, save the casters and rebuild them with plastic decking. Keep your eye out for decking jobs in progress and grab the scraps and off cuts.
rlitman
Long Island
Just use an exterior latex paint, and be sure to go over any end grain until no more soaks in, and then one more coat.
Paint will ALWAYS outperform stain.
bad_idea
Pasquotank, NC
I have seen Lowe's put plastic decking on clearance sales once in a while. A plank or two should build all the carts you need.
You could also look at the car dollies at HF. They are metal and should last a lifetime.
