Snap-On Torx vs Husky Torx
Mr. Tool
Found this interesting :lol_hitti
Professional Tool User
BC
It's true to a certain extent. Bit sockets are one of those things that eventually break regardless of brand. My Canadian tire impact T-40 socket out of all the ones my co worker used (including Mac and Snap on) for floor screws on 53 ft trailers actually lasted the longest before breaking.
FSrepair&fabrication
maryland
Operator error.... I can “feel” when something is about to snap. That means STOP NOW, get the torch and try to get it freed up before you have to get out the drill too. Peopele really get a kick out of wasting time making these stupid picture captions/memes.
Wrench97
Southeastern Pa
Work on enough rusty Volvo's and you'll give up on sockets and just buy bits 10 in a bag and use a socket adapter.........................
Tallpilot
Orlando
Not even the heavy duty disassembly bit sockets. Just an excuse to post an idiotic meme.
Wamsutta
Amarillo, Texas
That Husky socket looks like it has the top of the bit is missing.
Something is not right about that socket either.
Wamsutta
Amarillo, Texas
The Husky broke too. They both broke. That's the point.
Why don't I ever break any of my Torx sockets? I use a T30 for my air cleaner hold down bolts and a T27 for my STIHL weed eater. I've never broken any of them, but then again, I'm using a standard length ratchet with them; no cheater pipe.
uncwstudent
MS
That would explain why I find so many bags of torx bits sockets with the same sizes! That's honestly been a mystery to me for awhile.
2ndGearRubber
Pittsburgh
I try to keep 5 of every size on hand below T40. Torx are a consumable. I've broken plenty of every brand, normally they wear the edges down before they actually break. I stopped warranting, not worth my time anymore since nobody wanted to stock replacements. Zypher does very well for me.
I can hardly believe the guy in the picture broke 2 torx bits. Usually they'll round before that much force can be applied.
Wamsutta - If you're using a T27 for air cleaner bolts, it's never going to break. 10 ft/lbs tops on at most an M8 fastener? A torx bit made of Cheddar or another firm cheese might still remove those.
BC
If you ever have to deal with any seized or rounded ones, you're screwed. Don't get me started on those T55 Dodge pick up truck front eye bolts on the spring rear spring. Can't spin or turn it loose without either breaking
the torx bit or rounding the bolt and no room to aim an air hammer in at good angle sometimes.
CR888
You would need top shelf Snap On T27 bits for the heavy duty air filter service. Don't cheap out on those 8ftlb tools. Buy a wiha T-handle and you'll never look back.:thumbup:
itslow
marineman
Wild Rose, WI
Most of the torx I come across are interior, low torque screws but I've had my toptul non impact torx bits going full hog on my MG725 trying to get seatbelts out and haven't broken it yet. The only tool I've managed to break at work while using it as intended is a chrome snapon socket torquing head bolts.
mde8965
Florida
Question regarding Torx sockets from a DIYer, not a tradesman. I've broken torx sockets before mostly on interior seat belt removal building race cars. That was 20+ year ago. Now with cordless hand tools, one can use an impact wrench to break those loose with an impact Torx socket/bit. Or can you? Are the tips of an impact torx socket up to the task in your experience for things like seat belt or head bolts? Or is it just the lower "socket" part that's impact rated?
Reason I ask is these days I work on Jeeps a lot. And mostly in the Daimler/Chrysler era jeeps. Everything is torx on these things. Wondering if I should invest in a relatively modest (Sunex or similar) torx impact socket set. I have a cheap Chinese chrome set now.
As for the subject of this thread. Snap on stuff inst made of plutonium. I have always likened snap on stuff to buying into the innovativeness and the buying experience. Initial quality, nice looking tools, innovative tool solutions to most every problem, and a no questions asked warranty. Like buying a BMW instead of a Volkswagen. Its slightly more polished, more engineering went into it, there is the "I've arrived" appeal, but at the end of the day is that BMW worth nearly twice as much as the VW? And if you crash both into a brick wall at 50mph, they will both be FUBAR.
I would have a tool box full of snap on if I could justify it. But for a weekend warrior, its just so hard to spend the money for these tools since they are not making money for me. I have 2 Snap on ratchets now. One an old F720 (was my dad's I rebuilt it) and a 1/4 comfort handle/green that I bought new on eBay for $62. And I find, since I am just a DIYer I only use the Snap ons for lighter jobs and not the greasy sh1tstorm jobs. I use my USA Craftsman for that. LOL.
dsimatt
I've got the gold snap on torx socket set...yes it's expensive but made more expensive when you add up all the cheap brand's I bought and broke over the years. IMO these are a buy once cry once tool and if they do break it's warranty.
Regarding the picture, would be nice to have a video of them breaking, the husky snapped the end like every cheap one I've had, the snappy broke under a lot more torque.
crasher98
NW LA
x2 on having a jeep infested with torx bolts, x2 on the snap-on gold set, and x2 on make sure you're sitting down when you check out how much they cost. But they're the only ones I've never broken (driveway work, not pro), and I'd buy them again if I had to. Actually I'm pretty sure you can just buy the bits and replace them as needed.
Here's my torx drawer and my most recent broken torx, a GP T40:
View media item 92584View media item 92585
Don't have a torx wrench set yet because I haven't had to get at the e-torx bolt that reportedly is on top of the bell housing, but probably just a matter of time...
There definitely is technique involved, and a few of my busted bits were probably my fault, but if your jeep is rusty sometimes there's nothing to do but drill them out. The usual advice on jeep boards is that when you do get one out, throw it as far as you can into a field and replace it w/ a hex bolt.
