:headscrat
B Bert_ Well-known member Joined Dec 24, 2016 Messages 9,929 Location NW Iowa May 9, 2019 #2 Several things done wrong but the biggest is the dust collector itself. DC-1200VX-BK3 Dust Collector, 2HP 3PH 230/460V, 30-Micron Bag Filter Kit You bought a 3 phase dust collector and I'm guessing you don't have 3 phase... Last edited: May 9, 2019
OP J jmac2043 Member Joined Mar 2, 2015 Messages 22 May 9, 2019 #3 Not sure of the difference to be honest
P pattenp Well-known member Joined Jun 4, 2008 Messages 10,175 Location Virginia - USA May 9, 2019 #4 You need to return DC and get one that uses single phase power. 3 phase is normally commercial/ industrial power.
N Norcal Well-known member Joined Mar 16, 2008 Messages 13,796 May 10, 2019 #6 jmac2043 said: got it; thanks all, I'm an ....... Click to expand... Did you buy it new, or used? If new return it, if used there are options if it was cheap enough to make it worthwhile, 3 HP single phase input VFD's are pretty reasonable, details will help.
B Bert_ Well-known member Joined Dec 24, 2016 Messages 9,929 Location NW Iowa May 10, 2019 #7 3 phase has 3 "hot" wires, your Normal household power has 2 hots. Also, if the unit calls for a 20a circuit then that is what you should use. Not the 50 amp plug you have in the link.
W wyliesdiesels Well-known member Joined Aug 14, 2012 Messages 20,275 Location Modesto, CA May 10, 2019 #8 wow that was a major goof! helps to do some reading before making an expensive mistake.
R Rbreddin Well-known member Joined Jun 16, 2012 Messages 73 Location Alpharetta, GA May 10, 2019 #9 when you return the DC, make sure you pick up either upgraded bags or a canister filter that will filter down to 2 microns. at 30 microns, you're still breathing in all the "poisonous" dust
