too quiet around here....means he is typing up the Bridgeport story...
Oh jeez, I wish.
When Lara is here she forces me to work on the house - not by nagging but by example. She cleans, she rakes, she picks up around the yard. Things I can be bad at because I want to do things perfectly and when that's not an option I don't do them. Sigh.
I wish I had photos of the Bridgeport move. Here's the thing: since making the decision to start YouTube I've been thinking in terms of video. Trying to get my head around the process, the gear, the whole thing. Yes, I have yet to make my first video but it's pretty much all I'm thinking about now. And so I am not taking still photos.
Case in point - the day we moved the Bridgeport I didn't take a single still image. It amazes even me. This is a frame grab from an iPhone video - the only one that I shot horizontally. I've gotten used to shooting Instagram stories in vertical and things I deem of passing interest I'll shoot for IG but stills have sort of fallen by the wayside.
And that *****.
Anyway, for those who aren't on IG the move of the mill went very well. We had only one scare when I unhooked the trailer and the mill was past the axle and the trailer instantly tipped up in front. We'd blocked the wheels and then used the van's winch to ease the mill down. When we got to the last part we couldn't get the pallet jack's small wheels over the steel lip on the trailer so we called our neighbor and legendary guitar maker Saul Koll. Judiaann couldn't help herself, "Better call Saul!" Saul and I have exchanged messages a few times but hadn't met until I texted him to see if he could help unload the Bridgeport. He flew to the shop on his Vespa in minutes! I don't know if we could have done it without him.
So in order to get the mill into the shop I had to move the rest of the motorcycles into the living room and the yard but the mill landed safely in the shop and has stayed there. I have a VFD and three DRO scales from ebay waiting to go but I can't place the mill unless I completely revamp the shop. I can't revamp the shop without fixing or replacing the garage door. I can't just buy a new garage door because I need that ceiling space back so I need to make one...
It's like those sliding puzzles you had when you were a kid. To move one thing 10 other things need to be moved and each of those require 10 things to be done or moved.
So I closed my eyes and decided to finish the last project.
We had to slightly shave down the blocks we screwed into the wall as gluing the shelves together tightened them ever so slightly. But the shelves went on perfectly and then, for cleanliness and strength, we caulked the entire perimeter of the shelf and the lower cabinets.
To hide the wires of the TV I bought one of those kits that... hides the wires. It seems like it would be simple to do on your own but this is a clean solution. You punch two holes in-between studs and then install recessed boxes with a power wire. If I had not changed my mind about the shelves I might have decided to do this before I put the cabinets in.
I used the Fien tool to cut out the back of the cabinet and luckily it was flush to the wall. Surprise! There was no insulation in this wall - one of the few that wasn't opened up. I could have them shot with foam but this room is very stable temp wise so it's no big deal.
I eschewed a store bought TV mount and instead simply screwed a french cleat into the mounting holes on the back of the TV and another on the wall.
And that was that. The shelves look a little sparse but I'm guessing they'll look much better once there's books on them...
So now we head to the cottage to find the boxes of books that have been in storage for the last 7 years. Many boxes of junk have gone to good will and we probably could have saved a bundle when we moved if we'd done this purge before. Nonetheless the cottage is another collection of tiles that needs to be moved, sorted, organized before the books are found.
What's interesting about our book collection is just how technical it is. Mine is about 50% motorcycle related and 30% machining and fabrication with 5% dedicated to Bonsai and the last bit to "literature". Judiaann is about 70% cookbooks and 30% literature. Her literature is without quotes however.
Interestingly I would put books on the shelf and then check for deflection. More books and check again. More and more and more and they are not light books. I'd guess there's about 70lbs on that top shelf - maybe more. Still no deflection. I'm amazed.
So the house is a mess. The books are mess. The yard is a mess and it feels like I've gone backwards and not forwards. While the Bridgeport is a fair bit larger than the Rockwell it's disruptive presence is outsized. It is also forcing me to reconsider the shop and it's purpose and function.
All the while I'm trying to learn Premier and teach myself video. I've come to realize that I've painted myself into a corner and so I'm looking to hire someone who can help me get the YouTube thing started. Hopefully next week we'll have a plan for that and be able to get that going if I can afford the help.
To prove that I've been making an honest effort I spent 8 hours to edit this 48 second clip of Lara and I taking a day off and going riding: https://photos.smugmug.com/photos/i-Ts92rLC/0/8f10294f/1920/i-Ts92rLC-1920.mp4
It's filled with mistakes but it's also filled with a lot of lessons and a lot of learning.
So, sorry to be so quiet. When I can't see the solution to something I tend to get quiet until I can figure it out. I'm not there yet but I do see some light.
Gregor
