Can you recommend good drill bits for safety wiring?
jgelack
Hi, I'm prepping a motorcycle for the track and need to do some safety wiring. Can you recommend some good quality drill bits for this project? Thanks
dan.brown
You will want to get jobber length bits. That is the short ones. Drill the hole just a few thousandths larger than the wire. Have fun and keep the rubber side down.
Sent from my SM-N950U using Tapatalk
pstemari
Seattle
Jobber length is the normal size. The short ones are "stub" or "screw machine" drills.
Sent from my Pixel XL using Tapatalk
MoonRise
Buy fasteners that already have the safety-wire holes in them.
Because do you really want to try and drill through hardened bolt heads with a pretty small diameter drill bit?
You're not really going to do that by hand. You'll take each fastener off, clamp and position it in a mill or a decent drill press (which means you'll need that mill or drill press AND some decent mill/drill machinist's vise as well as the drill bits), drill the small diameter holes, clean and deburr those small diameter holes, and then reinstall the fasteners.
https://www.practicalmachinist.com/vb/general/difficulty-drilling-nuts-bolts-safety-wire-326365/
And do you need to have safety wire? Or can you use Loc-Tite type thread locker compounds?
J
jgelack
Safety wire is recommended in the novice groups, but required in the more advanced groups. Loctite is not an option, they need to be able to see that certain fasteners are backed up with wire.
fos373
If you want pre drilled, go pro-bolt.
Having raced for years and drilled lots, it will be trial and error at 1st, but gets easy. Slow and steady and lubricate.
Who are you racing with?
Hagatronics
Melbourne, Victoria, Australia
It's a deadset PITA. Even with a drill guide it *****. I found that you'd drill slowly and plenty of lube but the drill would grab and snap as it exited the other side. You end up with a hole with a hardened steel drill bit wedged in it.
I'd buy the bolts of they are available. You'll end up breaking lots of drill bits so probably not a lot more expensive anyway.
J
jgelack
I'm not racing yet. Just getting started with doing track days. Even though safety wire isn't required to run novice, I'm trying to stay ahead of the curve and learn how to do it, plus it just gives me peace of mind knowing that critical fasteners are backed up. I'd like to attempt to drill these bolts myself, but if I end up breaking too many bits and getting frustrated, I can see me placing an order with Pro-Bolt. Thanks for the advice guys!
