Over glasses safety goggles
branimal
Can anyone recommend a good pair of goggles that can be worn over prescription glasses?
I haven't worn eye protection b/c I find most goggles useless. Can't see my cut line, fogs up, etc. I'm just depending on my prescription glasses to keep my eyeballs intact. It's been working great so far..... but I know that's going to come to a tearful end at some point.
Thanks
rlitman
Long Island
B,
Another option is to get prescription safety glasses. Not really all that expensive considering the advantages.
I've been thinking about that for a long time. Some recent work made me regret (a little) not having them yet. Any suggestions about where to get the best deals on them? Costco perhaps?
dreamingmuscle
Tryon Oklahoma
Zinnioptical.com Just triple check that you have put your prescription in correctly.
I don't buy their 10 dollar frames but even upgraded frames and progressive lenses is $60 or so bucks.
I get two years out of them in a not so gentle environment.
I have not ordered any safety glasses though
branimal
Here’s one on Amazon that gets good reviews.
ransil
pa
I got prescription ones at walmart in the past, was $50 for a pair and when i got a new prescriptions just had new lenses put in them, last time the lenses were $80 , ill probaly find new glasses next time online.
Regular glasses i get from zenni never pay more than $60.
Sent from my SM-G920V using Tapatalk
930dreamer
Amarillo,TX and Stinnett,TX
I've had good luck with these prescription from Eyemart Express? They tint in the sun, can't leave them on a dash in direct sunlight or the rubber nose piece will melt.
Lucid Moments
Gainesville, Ga
I've got some 3M safety glasses that I wear every day. They do not look like safety glasses but they are, and have clip on side guards so they really do work.
dr_clyde
Holland, MI
Most of my working life I've been required to wear safety glasses at my job.
I have several pairs of perscription safety glasses. It's the best way. I find them no different to wear than my dress glasses and the only noticeable difference is the side shields.
A good set can cost a few bucks, but you only get the one set of eyes.
lakeroadster
Central Colorado
It's kind of tough to buy them without actually trying them 1st.
Be careful they don't rub the lenses of your glasses. If you have plastic lenses they'll get scratched from the safety glasses.
Macrosill
Long Island, NY
My son and I both use these. The best over the glasses I have found thus far. We use them both in the shop and at the range.
Monza Harry
Windsor ON
Side shields on regular eyeglasses isn't Eye protection! The lenses and frames have to meet impact standard to be legit safety glasses. Safety Glasses are **** at keeping dust out of your eyes, shields and goggles do that, safety glasses keep out the exploding tap, grinding wheels, cutters, and the like, not dust, Side shields are for visitors doing a tour not the guy doing the job. I would go buy the right thing for you, go to a proper safety supply and get some expert advice and get their recommendation. [Be it over glasses or proper prescription ones] Like mentioned above you only get one pair of peepers and yes both are required! Just my 2 pennies worth of free advice. Harry
bjcouche
If you need to wear safety glasses on the job, then I recommend getting a pair of prescription safety glasses. They will be way more comfortable, and if you are already used to wearing glasses, you won't notice that you're wearing "safety" glasses. Now if you are wearing eye protection, not just to appease the safety department, but to provide actual eye protection, I'd recommend using full face shields, (preferably with chin guards). I use prescription glasses, and then the full face shield when doing things like grinding. Glasses alone don't protect you from getting grinding grit in your face and eyes and a good face shield works well.
I have never found ANY safety glasses that fit OVER prescription glasses that didn't completely fog up in under 5 minutes. Some come with anti fog coating, but that's never worked for me either.
Also, not everyone can get prescription safety glasses. If you are VERY nearsighted and need thick lenses, You can get non safety plastic lenses with a high index of refraction, and thus have a thinner, lighter lens.
The ANSI Z87 lens material only comes in a LOW refraction index and large lens diameter. Thus strong prescriptions cannot be made with safety glass because the lenses don't come that thick. Depending on your prescription, bifocals, prism, etc. safety glasses can get pricey, but they should be comfortable and last a long time.
Brian
bugnut
Central Ohio
My vote is also for the prescription safety glasses. Skip the lighter weight polycarb(?) lenses and go with glass as they last longer and scratch less, especially if you work around dusty, gritty things.
I have been thinking of getting a Uvex Bionic Face Shield with Clear Polycarbonate Visor which gets amazing reviews on amzn.
jeff lary
Hartland Maine
I have had to have steel cut out of my eyes twice in my life. Both times I was wearing good quality safety glasses.
Both times the steel was a "spark" caused from grinding metal that bounced off my cheek then the inside of my safety glasses lens and into my eye. When I was lying back on a gurney with my eye numbed and a doctor using a Dremel like instrument to slice a pie shaped piece of my eye ball out to get the steel out,....
I now use safety glasses and either goggles or a full face shield, at the same time. When they tell you they are about to cut out a piece of your eye to get the steel out because it has rusted the in the flesh of your eye you will rethink wearing just safety glasses. Rusting just takes overnight to occur.
dr_clyde
Holland, MI
Been there, done that, got the t shirt. I think I've done it at least 3 times. Safety glasses and face shield, sometimes it just finds a way in. Occupational hazard working with welders and grinders.
"Pick out a spot on the ceiling, look at it, and DON'T MOVE YOUR EYE".
Monza Harry
Windsor ON
Glass lenses with the "Hardex" treatment that I bought when I was younger, for work will pit from grinding and connot be re-polished, just an FYI/ I won't do that again! lasted about 1 month. Harry
Voi
Western South Dakota
I also like a full face shield due to the fogging issue. I especially prefer a face shield that spaces the shield further away from my face which seems to help with the fogging issue and allows more room for a cartridge type respirator as well.
I don't know which face shields have that feature. I just know the last time I tried on a cheap one somewhere it seemed too close to my face and I didn't buy it due to the fogging and respirator concern.
There was a discussion here many months about using a mesh face shield which should eliminate fogging altogether but as I recall there was no consensus as to whether the mesh face shields (like those used for chainsaw work) would be able to stop something like a flying angle grinder wheel.
PhantomEB
Medicine Hat, AB, Canuckistan
Won’t use them as I see them as a ‘compromise’.
Another vote for either suffer with slight blurriness or pay up for prescription safety glasses. I prefer two pair, one for inside work and tinted for outdoor work.
DGersic
DeKalb, IL
Check out the DeWalt goggles. They fit over glasses, are reasonably comfortable, and do not fog.
I know, that’s hard to believe, but I’ve used them even doing yard work and working up a sweat without fogging them.
Sent from my iPad using The Garage Journal mobile app
TommyK
CT
Face shields are designed to protect the face. Safety glasses are designed to protect the eyes. One is not a substitute for the other.
CraigStu
Blacksburg, Va
I have been using a full face shield in the garage. Another method to look into is how your health insurance covers glasses. Is there a '1 exam per year' or similar coverage? I have played the game to get lowered pricing on sun glasses and shooting glasses. Also have been lucky when my employer changes insurance companies. Each time they change the rules start anew. IE you get glasses under insurance company X in June. Employer switches to insurance Y in Jan. You can get new glasses in Jan. I find my eyes don't change very much so I keep my every day glasses pretty current but a one or two back prescription is fine for sun or shooting or shop glasses.
mike1956
Beautiful Hudson Valley NY
I just wear those cheap buy by the dozen regular safety glasses over my prescription glasses. There's enough circulation to prevent fogging and when they scratch I toss em. They're cheap.
LeeG
Phoenix, AZ
I wear progressive bifocals. I have had the best luck with the Uvex S2510 OTG glasses
I still wear a face shield in addition when I am doing grinding or other heavy work, but I try to never even go into my garage without these safety glasses on. For me the real eye opener was when I looked saw burn marks on my old glasses from spatter that made it around my welding mask.
