Duty cycle matters, and there are a couple of definitions that are used to describe duty cycle. I would not be that concerned about duty cycle unless your compressor is "always" running.
How often does the compressor run during the day?
With my 240 gallon setup, I can do multiple brake jobs and tire rotations before they even think about coming on. If I need to cut a collar and bearing off an axle shaft, the tanks might drop 20 psi but they still don't need to come on to do the job if the tanks were filled... When do they do come on, one takes about 6 minutes to fill the tanks from 140 to 175 and both running together take about 3 minutes...
Duty cycle matters more depending on the size of the shop and how many guys are always using air. A production tire shop where there are production mandates and guys are taking alternating lunches and always running tire machines and impacts is a bit different than a smaller 1-2 man shop doing general automotive work.
What describes your situation?
I’m a 1 man show. I do run some intensive tools, like a couple 1HP air grinders, but it’s not terrible.
With my old setup, one 60 gal Husky, the compressor was constantly running if I was using air tools. The one full day I had using the Jenny, it was running a LOT less then the Husky, and it would catch up, and then turn off while I was still using the tools. So I’m sure with 3 tanks, it’ll run a lot less frequently.
The main thing I was concerned about was from things I’ve read on other forums. People saying that adding too many tanks to a system is really trying on the master compressor. But since I’m adding once slave compressor, That should help a lot also.
But ya, the Husky ran a lot. 3-4 hours a day strait depending on the jobs I was doing. If I did a couple sets of tires and had to clean up the beads, and then maybe clean up a set of cylinder heads, or something else where I was using air tools a lot, it would just run non stop until I was done.
I think with the Jenny and the husky, and then a 3rd tank to catch water, I’ll be set for my air system for a long time.
Those little Husky’s are good compressors. I defiantly got my money’s worth. Got it on sale for $475, and it’s gotten a lot of use. I added an auto drain, and then changed air filters and oil once a month, and it never failed me. But the it’s getting worn out.
