I found a similar ratchet today but mine is missing the Rolls Royce.:(
Tylermorris
Enderby bc Canada
Snap-on 14” pipe wrench
I received a little gift in the mail today from bmwrd0. :bowdown: It is a tiny 9/32” drive screwdriver bit that has been missing from my mostly 1942 9/32” drive set. I had almost given up on completing the set.
Set is looking good!
Tylermorris
Enderby bc Canada
Snap-on pliers And snips
Username already in use
I picked up a 1in drive Snap-On Torqometer in a hefty steel box today from the flea. Bout wore my arm off trying to carry that thing around! Came with a Williams 1in to 3/4" adaptor and 3/4" to 1/2" adaptor. I left them in the pic for scale. This thing is massive!
snapmom
Florida
Wow, that is a big one.
I found two Snap-on pieces today. One is a floppy 1/2” drive early u-joint only marked Snap-on with no part number or date code. The Ferret screwdriver bit isn’t marked Snap-On but it clearly is.
snapmom
Florida
Metric 3/8 dr. socket set. date codes 1938. Missing the 9mm but what the heck.
Provincial
Near Salem, OR
I found this S-9540A windshield wiper drive nut socket on Thursday. It fits 1955-58 Chevrolet and Pontiac.
davethorik
Norka, Ohio
I picked up 2 Snap-on hand boxes today.
First one is older, looks like it was supposed to have a tray (long gone). Came with a bunch of rusty random tools.
2nd box is a 1972 KRA-280 painted green but overall good shape.
LesserSon
PA USA
I don’t see any markings on these two 9/32dr square sockets, but they resemble the early SO ones in 1/2dr I’ve seen. The sliding Tee is stuck, and the drive looks like it was forced into a too-small socket. I suspect it was 9/32dr at birth, but had a run-in with the mother of invention.
Edit - here are two hex sockets I forgot to include.
As posted on the Garage Sale thread, these are my Snap-on finds from the Tahoe flea this morning. I like the vacuum grip cutters and the V flare nut wrenches.
I finally got a chance to take some pictures of the early vacuum grip dykes. I’m not sure when they were made.
-Don965039A9-5BC9-4E68-B6B2-58D104D63F66.jpgC213A328-DEB3-4115-AC4C-635057FCA57C.jpg5F6820BC-787C-49B0-BC1B-C7DD8FD7B752.jpgFB54A105-E72B-4409-BD5D-2B345D697428.jpg
LesserSon
PA USA
Don, you probably already know, but for interested parties, here’s my exercise in deduction:
Forged Steel Products was founded in Newark NJ in 1920. In 1922, the company moved to Newport PA. Around 1945-6, the Snap-on name replaced Forged Steel Products on tools, and in 1958 production moved out of Newport. So 1923-45, probably. Since the 1921 dimpled grip design patent date was frequently stamped on products, maybe further reduced to 1928-45? The way the cutting area is milled (from your earlier post) inclines me to guess early 1930s?
Without a date code stamp (anything on the inside of the handles?), it’s just a guess.
Does it have a model number?
LS,
Thanks for that information. I wasn’t aware of the exact timeline. I didn’t see any obvious additional markings but I will double check later today. I have some larger ones with the Snap-on markings on the inside of the handles.
Provincial
Near Salem, OR
About 35 years ago I picked up some sockets in an estate deal. I recently dug them out to share them. Among them were these Snap-On items:
No. 9001 21/32" Ford connecting rod socket. 1929
screwdriver socket 1/2 drive. Logo matches the other sockets. No numbers.
SW-160 1/2" 12-point socket. 1932
SW-200 5/8" 12-point socket. 1932
SW-250 25/32" 12-point socket. 1932
F30 clutch driver
TM30 clutch driver
TM27 clutch driver
snapmom
Florida
A odd stamping error. I like this font the most.
snapmom
Florida
They mostly show up in early-mid 50s wrenches. Some are much bolder. Notice too, they have the / instead of the - dash, odd for 50s tools.
I found this box empty at the flea recently and threw some 1/4” drive tools in it. I’m curious about the age of the box and what might have originally come in it?
Maybe swivel sockets. I have one I keep hole punches in.
Tylermorris
Enderby bc Canada
Small blue-point puller, and blue point.....?
MShaw
York, Pa.
The puller is a battery terminal puller. The other items are adjustable reamers. Used for fitting bushings after installation as in king pins and spring shackles.
jgromada
Maryland (between DC & Balt)
Are those Type 87? I have a pair similar to those except only 2 rows of suction cones running down the side. I think mine are early as they have no markings on the head of the tool, all markings are on the inside of the handles opposite of the suction cones. I haven't found any date codes yet, any suggestions of where they might be?
LS,
Keep in mind that until 1931, when Forged Steel Products was formally merged with Snap-on, they were still selling their own pliers under their own brand name (Vacuum-Grip) in addition to supplying Snap-on with pliers that Snap-on sold with the same brand name. Those pliers look like straight up FSP Vacuum-Grips to me.
Double stamp date code on this socket from last weekend. 41 and 45.
