Adding AC in my reloading room
Stefan S
Texas
I’ve converted my mechanical closet into a small reloading room. I need advice on the best way to add AC here which seems pretty easy... just pop a whole in the main trunk but I’m concerned about two things. 1) the velocity coming straight off the trunk and 2) how to set up the return air which sits directly below the unit and hot water tank.
For number 2 I think I can just add a small filter housing?
Thanks in advance for your advice!
cspcrx
Phoenix, AZ
watch your airflow volume. Can impact scale readings, not sure your reloading process. I have a fan I run and turn it off when I measuring loads because the digital scale is so sensitive it picks it up.
Jackfre
N CA
That's pretty cool thank you for the suggestion - how loud are these? The adjacent area is living space so I want to make sure it won't be disturbing when in use.
Check the specs for decibel level, but yes they are quiet.
75gmck25
Alexandria, VA
I'm not an HVAC guy, but check on rules/guidelines for having a return air vent in a mechanical room where you are running gas heat and water heater. You want relatively dead air flow near the burner so the flame is steady, and you don't want to pull gases or CO back into the house plenum.
Bruce
Stefan S
Texas
Good advice! I’m loading for accuracy so precision counts!
Stefan S
Texas
Bruce
There’s no gas but I can see your point on this I think I’m leaning towards the fan
