Drill Press Vise - Advice
1956ford
Cypress, Texas
I recently bought a Delta Homecraft bench top drill press. I believe it is 1957 vintage, operates perfectly, well maintained. HEAVY!
For ordinary home / garage use, is a drill press vise recommended?
If so, what are reasonably priced and decent brands.
Is a one dimensional vise sufficient? Or is the cross-slide, two dimensional one that much more useful?
Thank you for any suggestions.
CobraRed
Yost Dpv-4 or DPV-5 is best bang for your buck IMO.
$40-50, I went through 2 Irwin cheapies than got this. Thousands of drill holes, no issues with it.
As for cross slide, I suppose that depends on what you need it for. Depends on the user.
Davefr
OR
It really depends on your projects. For me, this is what I always have at the DP since you can use it on 5 of it's 6 sides. Don't even think of getting one without the two V grooves in the stationary jaw.:
One of these might be better if you anticipate a lot of clamping of work to your DP table but you sacrifice versatility.
I have a crossfeed vise but rarely use it. I've also rarely use a DP angle vise.
exmaxima1
Midwest
I like V-groove idea, though I rarely use it. For me, stepped jaws are the most important. Makes things much faster, and saves scarring the vise
NC Rick
Asheville
Nice drill press! I’m with Dave on the vise selection, being able to tip the vise on its side adds a lot to versatility. And x-y table (preferably with graduated rotation also) is good if you have to layout accurate hole patterns. You can do the math or use an internet calculator for hole patterns in a circle as an example. Learn to use a spot drill if you are using one of those. Forget about milling with one.
zkling
For that drill press, a vise like the first one dave posted, a fence and a few good sized c or f clamps should do all you need.
Putting a float lock style safety vise on that small of a drill press will be a royal pain (in my opinion).
lilredex
Toronto
My most used DP vise is a HF type mounted on a track. Easy on, easy off ....never an excuse for accident prone hand holding stuff.
Believe yours also has a rectangular table.
shawhite
Those type of vises take up a lot of vertical height on a bench top press which has limited headroom as it is. I can set up my float lock quicker than I could clamp something in one of the screw type vices. I would personally use a clamp vise before I use the screw type drill vise. Unless I needed parallels or a v block.
https://www.homedepot.com/p/Yost-6-in-Drill-Press-Vise-Clamp-DC-6/207206028
1956ford
Cypress, Texas
Thank you all. Outstanding information. I will follow up your suggestions and links.
El Wifo and I are looking at homes in Arkansas soon and some have shops, so hoping one works out.
matt_i
SE Michigan
My favorite drill press vise is an abused 6" Kurt milling vise knockoff. It weighs ~50-60 lbs.
I like the Heinrich for fast clamping but nothing will touch the mass of the Kurt knockoff.
tool_scrounge
Southern California
Delta Homecraft 11" drill presses are impressively heavy for their size, but the table is not too large. I would get a 3" Palmgren like Davefr showed in the post above.
