2019 Garage Sale Thread
Magnum440d100
Indiana
AND, saving the best IMHO for last, this 10mm...
I bought a 117 piece craftsman kit when I turned 18. I really do not like the laser etched (it’s worn off a LOT of my sockets). I’ve lost a few, and today’s haul yielded some missing pieces to help fill gaps...
r_olson_06
SD
Here is the bottom box/chest. It is solid despite the surface rust.
Best of all, I paid $100 for everything!
Going through it now and upgrading my box(es) as I go! Haha
Hey,
Is that big wooden screwdriver a Plomb or Proto?
Gidge
New England
Picked this up recently, I'm thinking it is either an early Chemistry lab burner or a warming station for old cast iron laundry irons. Any ideas ?
Magnum440d100
Indiana
If that is aimed at me, then “cool!”
I don’t have many PLOMB/PLVMB stuff. But I do have a ratchet and some sockets, and now these screwdrivers.
I’m gonna have to start ANOTHER tool box for stuff that I’ll never use, but it’s awesome to have....
bluebolt
Benton LA
No pics of the 'stang? :(
It's an early 90's foxbody Mustang notchback, stock on the outside except for wheels, Ford 302 stroked to 331, World iron heads, Edelbrock Victor Jr intake, C4. I figured out the primary accelerator pump circuit was plugged and the timing was way off. Ran a lot better when I got done.
Rickster
SE PA
Couple of garage sales this morning netted a 1/2dr Williams Superratchet (already took it apart, cleaned & lubed), a 5pc set of 1/2dr Proto Pro impact sockets and two mini pocket screwdrivers!
Friday Flea finds...
The Lilliputian high speed drills are various brands. They came in the same batch as the fine work pliers, which are Klein, Utica, and an unknown brand, with a tiny, clear, but unfamiliar logo on the inside of the handle. I will post a zoom later.
The flare nut wrench is a Duro-Chrome. First one I have seen in the wild.
The Heller Masterench is a 6-incher. I think I needed one for my collection.
The screw pitch gage is interesting. One end is marked "AMER NAT" (a reference to American National threading system), and the other is marked "WHIT" (for Whitworth threading system). That's totally understandable. The strange part is that it has one name and location ("GEORGE ANGUS & CO LTD LONDON") on one side of the case, and another name and location ("MOORE & WRIGHT SHEFFIELD ENGLAND") on the other side. I suppose one is an OEM and one is a retailer. It's gummed up so I haven't actually looked at the blades yet.
SilverDeck
Rickster: what do you use to those Supertatchets apart? I have several that could use a cleaning but can’t get the face plate unscrewed. Do you have a special pin spanner for doing that?
Rickster may have his own trick, but Williams made and sold a modified version of one of their pin spanners (No. 420) to open the 50's and later era Superratchets. You could make one with just a little filing on the pins from any pin spanner with 7/32" pins that are 1-1/4" center to center apart (which is a No. 420). See this thread here.
Oily Nails
West Yorkshire, UK
Lugz,
GEORGE Angus & Co. Are/were a Gears company here in the UK for a couple hundred years, think they got bought out and "disappeared" in the 70's-80's.
(I'm a manufacturing engineer in process/fluid control here in UK, so I've heard the name)
Moore & Wright will be the manufacturer of the gauge. Most of my personal measurement gear at home is M&W
Not massively unusual to find find engineering firms names on M&W stuff here in the UK, clearly someone carried one home to USA!
Best guess is that George Angus may have ordered the gauges as salesmen tool or customer give aways.
Thanks for the 411, Oily Nails. I was hoping you would see that and chime in. I had done a little Googling and quickly discovered that both firms go way back, that M&W was making precision tools, and George Angus kept popping up in racing circles. You and Farmer J. are my go-to guys for UK info! :thumbup:
Rickster
SE PA
I just used an old Craftsman flat blade screwdriver and tapped it with a small hammer!
Oily Nails
West Yorkshire, UK
No problem Lugnutz , happy to help whilst I sit and browse GJ waiting for my plane in Düsseldorf. HOMEWARD BOUND!!
Although did have fun geeking out on intercompany factory audit in Germany... Hazet tools everywhere some clearly from when the factory opened :D
Bobcat753
New Hampshire
Finally got a chance to go pick up my shaper. Turns out it is a 1893 Smith & Mills Co. 16 Inch Shaper. Also I was able to get the 1898 E.F. Allen & Co. No.3 grinder added to the deal. Total for both pieces was $300. Can't wait to start restoring them and then using them!
HeelSpur
WV
What size is your flare nut wrench? I have the 7/8 x 1 1/8. Looks to be only 4 or 5 sizes.
alinc100
Dearborn,MI
One quick sale today. Didn't yield a lot but it was on the way to lunch after getting decking boards to spend the weekend on a home project.
Starrett 4inch and 6 inch combo square heads,one is modified,centerfinder head,Craftsman DBE,powrkraft adapter,Taiwan ratchet,Craftsman =v- socket missing it's allen bit. Going out in the garage now to look for 6 and 4 inch blades,sadly I don't think I have any...fingers crossed...
Magnum440d100
Indiana
Picked up these Husky 1/2” drive ratchets for the princely sum of $2 each.
One was locked up and the other free spun. Took them apart, and made 1 good one out of the 2. The “good” one works great but the gear has some marks/damage. I put some weight on it in many positions, and no skips/jumps, so it may work.
Going through yesterday’s haul still. There are enough powerbuilt branded sockets for a complete set, so I will be putting together a “loaner” box. A box that if tools went missing or came back incomplete, no big loss....
wrenchguy
NW Indiana
Kinda into the bigger stuff like another guy i know. good luck with ur projects.:thumbup:
bmwrd0
Beaver Fever Oregon
Hit two estate sales and a Restore:
SK bit driver, SK extensions, Herbrand ignition wrench, Williams 3/4dr socket, Challenger flex-head, Cornwell and Williams 3/8dr sockets, Proto Impact socket and Williams extension, P&C driver, P&C100 DBE, Trutest ratchet (this thing is smooth as silk) A 1mt to 2mt adaptor, Snap-on 15mm wrench and an old Portland PD patch. $15 for all that.
Oily Nails
West Yorkshire, UK
Bobcat I know I joked about you pulling a "hold ma beer" when you first posted your visit to that place... Well... With the catch pan on that grinder I believe you can say Hold ma Keg!
:D
Bobcat753
New Hampshire
:D
Thanks Oily! The grinder could be a bird bath with how big the tray is!
BC, is that monster a wet grinder?
Nope just a normal grinder with a huge quench tray.
Here is that British screw pitch gauge...
No estate sales for me since today was a travel day to Tahoe to assess the damage from our harsh winter. I stopped by Honza’s place to pick up an early S-K carry box that I had bought from him months ago. I guess it qualifies as a garage sale purchase since it came out of Honza’s garage.:)
Provincial
Near Salem, OR
Lots of sales today.
Photo #1 is the first stop, the estate of a Boeing electrical engineer. Lots of electronic stuff, including a small "steamer trunk" with plastic drawers full of things like resistors! Spent $12.00 total.
Boeing decimal equivilent chart (almost identical to a Starrett version I have)
#8 lock washers and aircraft self-locking nuts
Wilton 2-1/2" drill press vise
AMP terminal crimper, professional grade
bag of chuck keys
Magnifying lamp. No identification, but high quality.
Photo #2 is the Small stuff at the second stop. Out in the country, just a guy downsizing. Many interesting items but most priced too high. $22.00 for these items.
12" green porcelain lamp reflector (new)
Fairmount obstruction wrenches, 1-1/2", 1", 7/8"
Nickel Plated pump oil can
Proto 3/4 chevron combo
Proto 5/8x3/4 manifold & starter DBE wrench
Giller 9/16x5/8 manifold & starter DBE wrench
Various sharpening stones
Photo #3 is a Harbor Freight tubing roller at the second stop. $120.00 and it is unused. I bought it for a project I am starting.
The third stop was a bust, but at the fourth, I saw an interesting pair of pliers. I offered $0.50, but he insisted I pay $1.00 and take all the items lined up in the photo. Sure enough, the pliers are marked AMPCO-P31-BE CU-USA!
Photo #4:
AMPCO non-sparking pliers
Klein Linesman Pliers
2 unmarked screwdrivers
web clamp
Photo #5 is the AMPCO markings
Photo #6
The stubby screwdriver was at the fifth stop. It cost $0.50, and it is marked _ _ _ 2 in the black circled area. Does anyone recognize it?
I'll use another post for the last stop.
Provincial
Near Salem, OR
The last sale was a TOO. As I left the last advertised sale, I noticed a bunch of cars parked at a farm building. Sure enough, when I approached the driveway, there was an estate sale sign. Apparently, they hadn't advertised it very well. By then it had been going for three hours, and was picked over. I checked it out and found that the pickers had overlooked a few items, and I spent a total of $58.00.
Photo #1:
A cheap imported trowel so I don't have to borrow my wife's good one when I dig up the irrigation outlets to fix them.
Plomb 1246 1-7/16" pebble combo
Fairmount 1-1/2" DOE obstruction wrench
Craftsman -V- 42794 RHFT long flex ratchet
Photo #2:
Plate lifting chain sling and clamps
Photos 3,4 & 5:
3"x 60" Belt Sander
The belt sander was bolted to a post with the redi-rod you see next to it. It is not factory made, but some parts are castings that were probably part of a kit. The drive wheel has the name of our local high school cast into the web, so it was either cast for them or by them. The tension adjusting parts may have been made, rather than bought, and they are well made. I believe that it was built as a project in a metalworking class. The workmanship is quite good. The only weakness is that the mounting plate is somewhat thin, and thus flexible. If mounted to a solid vertical surface, it is adequate, and gravity provides the belt tension.
I plugged in the motor, and it operates properly. It does not have a grounded plug, and it did not trip a GFCI breaker. I do not see a data plate on the motor, but it may be mounted so the plate is toward the mounting plate. It appears to be 3/4 to 1 HP, 120/240V, wired 120V now.
It is pretty nice that the sander has a local connection.
I feel pretty good about finding the Craftsman ratchet. It isn't perfect, but pretty nice, and works well. The "patent pending" marking should age-date it somewhat. I've wanted one for a while, but not badly enough to pay Ebay prices!
Prov great scores! that ratchet is about as rate as the 3/8 spinner ratchet, and I really like the shop made sander! Looks to have the cooling cup built in? Is the frame aluminum? I wonder how many aluminum cans they had to melt to cast that if so!
bmwrd0
Beaver Fever Oregon
Prov, are you talking about that sale on Fir Villa? I was out there around 11 and it was pretty picked over. Spent $8 there. Way overpriced on a lot of things. Didn't ask about the two good vises.
Provincial
Near Salem, OR
BMW, too bad we missed. If you are talking about the estate sale (not the garage sale on the corner) I left just before noon. If you saw a white F250 with a service body, I was there. I was unbolting the sander after 11:00.
The one heavy vise with the pipe bending provisions was being kept by a family member. Someone had bought a leg vise when I arrived. The broken Reed was a sorry sight.
I was thinking I can give you the Klein linesman pliers I picked up this morning. It was thrown in with what I wanted, and the markings on it are pretty good. Let me know if you want it.
Provincial
Near Salem, OR
Thanks, Outlaw!
The frame that supports the two wheels of the sander is cast aluminum. I believe that is was factory made. The shop-made flat bar frame is located behind it, and it has feet that bolt to the area behind the cooling cup.
The cooling cup is shop made by welded fabrication using pipe and flat bar. It is integrated in the flat bar shop-made frame. The cast iron part between the wheels is the backing support for the belt working area.
