ez-duzit
I see this a lot: people hire professionals to advise them and then ignore that advice.
I cannot afford to totally demolish the building, including the slab, and rebuild. Probably can't afford to do the extensive repairs the way the engineer describes (tearing the rock facing off the front, all sheetrock and siding off the walls, etc.).
What you are dealing with is not that uncommon when it comes to back yard shops or garages. Its definitely not constructed in the best manner, but that doesn’t mean it’s unsafe. I do alot of remodels where we get into framing such as what your dealing with. The biggest issue I see is the lack of adequate attachment with the rafters to the top plate. Simply installing additional blocking in between your rafters and to the top plate will make a big difference in structural integrity. It’s inexpensive as well, and not time consuming. Once you’ve done that run some strong backs at a diagonal across the ceiling joists. That will take any flex and additional movement that may occur in the future. You’re talking a couple hundred dollars max in lumber and 3-4hrs if ur handy and have the proper equipment. Just because a structure is not plumb, or is out of square, or whatever, does not mean its structurally compromised. You just have to decide if the cosmetic part of it bothers you enough to not look past it. Being a rental property, I’d rock the ceiling, insulate it and call it a day. This is my entryway ceiling in my home. My company does alot of difficult framing details. Dont let the naysayers get to u. They wouldnt thrown good money over bad in your situation either.
Quote:
Originally Posted by DWinTX View Post
I cannot afford to...
Come on! That's the same mantra the original builder used when someone suggested that he do it right.
it might just be sloppy workmanship from many years ago, never plumb the walls to begin with
My post #33 asked the question. What's the harm of leaving it alone ?
You said you wanted to store some projects ? It's a rental property. Are you planning on using it regularly ? Make sure that's in the lease.
I'm an "old building guy" -- so .... I have seen my share of poorly built 50 year old outbuildings on 125 year old properties.
You can't "fix" your building. It's a hard thing to tell people after they buy. You can -- stabilize it ... if it even needs it .. but you can't fix it. Basically that's what the engineer told you. The fix will be more expensive than replacing ..
A bad foundation or slab -- can be fixed if the rest of the building is fine. I bad roof can be fixed if the reat of the building is fine. There is no point in partial fixing that building .. it needs both ... and the walls.
I had this not long ago .. couple bought a property with a barn. They now wanted to take the barn and make it into a guest space and office. And build another storage building .... I told them to build cottage and office ... and keep the barn for storage. To get the "barn" ready basically required it to be dismantled.
Actually, leaving it alone is still one of the things I'm still considering. But the projects that I'm storing are classic cars. Two of them are shells on body carts, and none of them are worth big money, but they're still cars. If I was just storing random junk in there I definitely would just leave it.
I do think I want to stabilize the foundation though. no matter what I do to the building, if that foundation keeps dropping it won't be good for it. So I'm curious about your comment:
I wondered if leveling the foundation could de-stabilize the building to any degree. The foundation guy put a level to the floor and then to the ceiling joists directly above and said they were on the same plane, for whatever that's worth.
I don't know if it's moving, haven't owned it long enough to tell. I guess if I choose to fix the roof, I should do the foundation first. If I choose not to fix the roof, I shouldn't mess with the foundation.
Frankly, a lot of making that decision will be who I can find to fix the roof and what it will cost. I'm searching for framers now, we'll see what I come up with.
How long has it been like that? It was prolly framed like that. its all melded, clinched now, leave it. Lets see ridge line for sag.
