Ever see Channellocks modified like this?
dwasifar
Here's an ebay listing for a set of 440s modified to be a cutter at the tip:
This is an interesting idea, don't you think?
jumbojak
Surry, VA
Interesting, but I can't imagine that working well with channellocks. There's too much play in a tongue and groove joint.
59'trump
I like the idea, never tried it. It would be difficult to grind all of that material out without softening the metal. Time and a cold water bath I suppose.
PhysicsDude
Dallas, TX
That's very interesting.
440 jaws don't line up parallel when they close, so the modifier must have ground extra material off the tips to get a flat surface. I wonder how well they actually work.
I also wonder how/when they ground down the cutting tip - if it has the same hardness and heat treat as the rest of the pliers. It looks professionally done with a machine - not some shade tree machinist with a grinder.
redwrench60
East Tennessee
Looks like they simultaneously ruined a good pair of Channellocks and made a useless set of cutters. Truly one tool to do neither job well. No wonder they're for sale.
Spacey_G
Maybe you could grind it so that the cutters line up when you push the jaws all the way to one side or the other.
