Old Briggs and Stratton engines with points and condenser had a tool like that to compress the spring to install a new condenser. I modified a pair of old channel locks to make mine 50-55 years ago. Not much use since everything is now electronic ignition. On those you changed points and condenser and put a new flywheel key in them now you get to replace the much more expensive coil assy.
