Snap-on, Stahlwille, and Nepros Comparison
jdavis
North Carolina
I was recently looking for comparisons between Snap-on, Stahlwille, and Nepros ratchets, since they're (arguably), the best brands of ratchet from the US, Germany, and Japan. I couldn't find a comparison of them, so being a bit obsessed with ratchets, I bought one of each. I figured I'd make a comparison, since I previously couldn't find one.
I like locking flex-head ratchets, and chose 3/8" drive for its intermediate size (and intermediate price). However, Nepros doesn't make a locking flex head (at least not one that I saw). For that reason, I chose to purchase a 1/4" Nepros instead of a 3/8", since I thought a non-locking mechanism would be more useful in a small ratchet. I've attached a picture of all 3 beside one another.
Because the Nepros is substantially different than the other 2, it won't quite be a 1-1 comparison with the others. I'll review it first, and get it out of the way. The Nepros has, without a doubt, the best fit and finish of the 3 of them. It feels like I'm working on my vehicle with a piece of jewelry, instead of a tool. There is no side-to-side play in the flex joint. The hinge friction mechanism is surprisingly stiff, but I'm skeptical of how well it would work on larger ratchets, or how it would react to oil and grease (it's really not the tool I'd use for a job that dirty though). It's a unique mechanism that doesn't get its resistance from the hinge or from yoke friction. It has a little (presumably) spring-loaded rubber brake that can be seen in the attached photos. It's not easily adjustable. I suppose if you really wanted to, you could take it apart and put a thin spacer underneath the spring (again, I've never actually had it apart, so I'm making some assumptions). The Nepros has the least driver play of the 3 of them, and has the most teeth at 90. The backdrag is so low, I sometimes can't tell when to start using my fingers. In my opinion, this tool is a must for accessing small, hard-to-reach fasteners. I paid about $120 for it, including shipping. It made it all the way from Japan in about a week. While I don't think I'd like the larger ones, part of me wants to purchase one in blind faith, due to my experience with this one.
As for the other 2, each one costs about $165 in the US. The Stahlwille can be had for about $100, but I didn't shop around very much. I bought mine from KC Tool. They were prompt, but expensive.
The Snap-on and Stahlwille both have 80 teeth. The Snap-on has the most backdrag (still low), and leaks oil around the driver, due to being oil-filled (still far less filthy than the places it will go, but I'm OCD and don't like that it leaks). Its driver also has more play than the Stahlwille, but neither are overly loose. The Snap-on is the quietest, and the Stahlwille is about as loud as the average ratchet. Both mechanisms are of high quality and function very well, but the Stahlwille is better IMO.
The selector is more positive on the Snap-on, and it's a little easier to switch. This is because the Stahlwille's selector is more beveled and rubs against the head a bit. Both switches are easy to use though. Also noteworthy, is that the Snap-on's selector switch locks into place better when the ratchet is under torque, helping to prevent a bump from dislodging it, but the extra beveling of the Stahlwille serves the same purpose. Also, to be clear, I've never had either of them come out of the selected setting. Both selectors work fine, but the Snap-on's is a little nicer.
As for the head, the Stahlwille has a smaller profile, but not by much. The Stahlwille is quick-release, and the Snap-on isn't. I prefer flex-heads larger than 1/4" to not have the quick-release mechanism, since I like to brace the back of the head with my hand much of the time (at least when I'm underneath the vehicle). I don't think Stahlwille sells this particular tool without it, but the Stahlwille's (and other German brands) that aren't quick-release have an exposed gear backing instead of a solid backing like the Snap-on (and other American brands). I can see pros and cons to each design, but I think I prefer the solid backing. With that said, I have never used the exposed-gear design.
The hinge and locking mechanism is where the biggest difference is. The Snap-on's hinge and lock are orders of magnitude better than the Stahlwille's. This difference is significant enough to make a difference when using the tool. The Stahlwille's hinge has a small amount of side-to-side play, where the Snap-on has none. The Stahlwille's locking mechanism has a total of 4 positions (-30, 0, 30, and 60 degrees), and the Snap-on has 11 (spaced evenly between "about" +/- 75 degrees). The Stahlwille's locking mechanism has a lot of play in it, where the Snap-on's has much less. I've included a picture of the 2 extremes for each one in the 0 degree position. The Stahlwille's lock is button-operated, and cannot remain unlocked when using the ratchet. It's also easy to push the button on accident when spinning the ratchet by its head. The Snap-on's lock is slider-operated, and can remain unlocked when using the ratchet by pushing the slider back and toward the right (image attached). With that said, if your hand is up near the Snap-on's head while it's unlocked, it's easy to bump the slider and cause it to lock. The Stahlwille's hinge is pinned, has very low friction, and cannot be adjusted. The Snap-on's hinge is screwed, has substantial friction, and can be adjusted. It's worth noting that the hinge was uncomfortably tight when I received the tool. It wasn't an issue since I could loosen it, but that's the state it was in right out of the box, for those that care.
Personally, I go back and forth on which grip I like better. I will say I read that the Stahlwille's comfort grip tears up unusually fast, and my experience seems to confirm this. It has a few little marks, and a cut in the rubber. It's not bad, but given the amount of use the tool has seen, it's worn faster than any other grip I have. With that said, the Stahlwille's grip is comfortable, and is clearly designed to keep the grip centerline as far from the pivot point as possible, maximizing torque. However, moving your hand to the rear of the Snap-on's grip is not uncomfortable, and anything you couldn't break loose with it would probably best be done by a 1/2" ratchet.
The last 2 differences I can think of are obvious from the pictures, but the handle is thinner on the Stahlwille, and it's unpolished, unlike the Snap-on. I suppose this could be good or bad.
All things considered, I'd probably pick the Snap-on over the Stahlwille, unless I was looking at fixed head ratchets. For a fixed head ratchet, I'd probably pick a Stahlwille.
JBH
Thanks for the comparison!
I'm surprised your Stahlwille has so much play. I have the 1/4" drive version and it's really tight.
I agree Snapon's locking flex mechanism is well-engineered, probably second to the Gedore dial-lock in terms of locking flex head designs.
I also don't like that Stahlwille's always wants to snap to a detent. Just bad design.
In 1/4" drive at least Stahlwille feels very similar to Nepros in terms of backdrag. Both are not as smooth as Koken, but still usable. Nepros is, as you noted, quieter. Snapon Dual 80-really-72 is notably cruder feeling.
mr.lemons
UK
Great comparison. Refreshing to read an objective opinion about a Snap on tool. I've had my eye on the Stahlwille for a while but I think the inability to disengage the lock may limit its functionality in tight spaces. Still want one though.
Superbec
Netherlands
why would you pay 160 for the SW?
try a Gedore when you get the chance , the 80? tooth ratchets are impressive
anetode
Nice review! Takeaway on the Stahlwille: stick to the metal handle non-flexhead versions of the 80t.
If you're ever feeling adventurous again, do try the Koken Z ratchets. Low tooth count and no locking mechanism, but the feel makes up for that.
jimmyin3D
southbay, CA
Yeah the Koken Zeal’s are I think 36 tooth but exceptionally made. Low backdrag, smooth precise construction. And they are pretty compact, I think I measured against a GW 84 and the Koken was shorter.
Here are some pictures of the 1/4 and 3/8 Zeal flex heads and the 3/8 ratchet adapter:
toddmorr
Potomac, Maryland
Yes koken zeal are really nice, but I actually prefer the 3753 or what's called the 753 series. Think it's 24 tooth, even less back drag than zeal, really smooth, but the nicest thing about it is the knurling. Wow you pick it up and it feels like a million bucks, never seen knurling that deep and detailed on anything else. Beautiful. You can buy that ratchet for 30 bucks new too on Amazon jp
Sent from my SAMSUNG-SM-G930A using The Garage Journal mobile app
J
jdavis
North Carolina
Yeah, my Snap-on's feel a bit more crude than the Stahlwille and Nepros as well. I think I saw the Gedore dial-lock when I was looking at German ratchets. I attached a picture of what I think you're referring to. Is that the mechanism?
J
jdavis
North Carolina
Thanks! It's still a great tool, despite the limitations of the locking mechanism. I used it a lot when putting the exhaust on my car, and there was nothing I couldn't reach with it.
J
jdavis
North Carolina
Well, I got ripped off. lol. I checked other sites and saw them for about $100. Then I realized they would be shipping from another country and I assumed the shipping would add up to what I paid at KC Tool, which stocks German tools in the US. I thought I was being clever and getting faster shipping for the same price, but I never actually checked the shipping costs on the other sites until after I had bought the tool. I should have bought it from MisterWorker.
As for Gedore, you're the 3rd person that has told me this. I'll definitely try them.
J
jdavis
North Carolina
Thanks! I'll have to try some koken stuff based on what everyone's telling me. I usually don't like low tooth count ratchets, but everyone that's ever used koken's stuff seems to really like it.
J
jdavis
North Carolina
Those look really nice. How do they compare in size to something like a Snap-on? I know the GW 84's are small, but I've never seen one in person.
J
jdavis
North Carolina
Is this the one you're referring to?
https://www.amazon.com/dp/B002P919PO/?tag=atomicindus08-20
JBH
Yes. They only make one body with that design, though it is available with 3/8" drive or 1/2" drive.
View media item 91413
Skin
Boston
Snap-on locking flex really cant be disengaged. The slightest nudge and it re-locks. If you try to use it as a regular flex it will just frustrate you. The best locking flex has always been, and remains to be, Matco.
Tallpilot
Orlando
I did the same thing once. I appreciate KCTool having a good selection of German tools available in inventory but just like McMaster Carr he charges a steep premium. If you aren't in a rush there is almost always a cheaper source.
JBH
Hmm. Mine (1/4" drive) requires some - not a lot, but some - effort to move the slider and re-lock it. It can easily be used unlocked.
Is it different on the bigger ones, or do we just have yet another example of abysmal unit-to-unit consistency from Snapon?
J
jdavis
North Carolina
Is the width not an issue in tight areas? They look a lot wider than most. I'm definitely interested in the locking mechanism though. That, and my German friend told me Gedore was his favorite tool brand. I bought some Gedore pliers. There isn't a whole lot to say about pliers though. They squeeze like you'd expect. lol
J
jdavis
North Carolina
Yeah, my 3/8" is very easy to bump into the locked position. My 1/2" isn't too bad though. I can see where that wouldn't be an issue with Matco's design, but I've heard the Matco locking mechanisms tend to break. That alone wouldn't stop me buying one, but I hate Matco with a fiery passion for reasons I detailed in the thread "Bad Experience with Matco". They actually tried to deposit a refund today, got the sign wrong, and billed me a second time for something they shouldn't have billed to begin with. So I won't be buying their stuff any time soon.
J
jdavis
North Carolina
Is that something Snap-on is known for? I definitely noticed a big difference between my 1/2" and 3/8", but I assumed it was due to difference in models.
Tallpilot
Orlando
I have all 3. The 3/8 is easier to bump than the others by a pretty big margin. The spring tension on the other two feels stronger. I usually use it in the locked position so it doesn't bother me too much.
I recommend them as the best first Snap-on to buy. But if you do this for a living you will probably want a couple more styles.
JBH
I've never tried them in tight spaces. I probably use 1/4" drive or a bit ratchet 500x for every time I need something larger. However, here's a comparison to some others for frame of reference:
3/8" drive
View media item 93489
1/2" drive
View media item 93490
Note that the two Gedores are exactly the same size. The only differences are the drive square and the model stamping.
Indifferent to poor quality control? Based on my admittedly limited experiences, yes.
See here: https://www.garagejournal.com/forum/showthread.php?t=411095
