Can anyone reccommend a 37° AN flaring tool?
Major Ramifications
River Ridge, Louisiana
Hey guys,
I have been meaning to re-plumb some stuff on the truck, fuel line, transmission lines, etc. I have the regular 45° flaring tools, but it seems that the high flow fittings all use the 37° flare. I figured it would be no big deal to get an AN flaring tool, but wow, they cost much more than the 45° types.
So, I am looking for something decent that doesn't cost too much. The whole idea of making the flares is that I figured it would be cheaper and better to run aluminum tubing rather than braided line. I know I still need braided line where it will be subject to movement. But if I have to spend a bunch on the flaring tool, then I may just as well get the compression AN fittings that go on the end of the tubing.
The J
We used the one from Summit racing.
http://www.summitracing.com/parts/SUM-900311/
It works ok. The toughest part is evenly gripping the tube and tightening evenly. It takes a little practice to get it right. In the end, it made a clean and even flare with no leaks. I used it for fuel lines.
It's worth it for the price, but I have no experience with others. For the price, I expect it to work but take some careful technique to get it right.
afazz
Pittsburgh, PA
I did a lot of research into this before buying my Imperial, and it seems there are three popular models: Ridgid 377 ($125), Imperial 400-F ($350), and the Mastercool hydraulic setup ($300). I bought my imperial 400-F and I love it, I've used it on 3/8" stainless and 5/8" Aluminum so far with no trouble. If you will never do stainless lines, something cheaper would probably work.
Major Ramifications
Hmm... I may be on the lookout for a used one, then. What is generally the first thing to wear out on these? Is it the gripping grooves in the tubing holder or ?
Unless my life changes dramatically, I don't see myself doing enough 37° flares before I die to justify a $350 expenditure.
scott37300
Wisconsin
So your hand flare kit costs more than the mastercool hydralic one? I have never used the mastercool but everything I have read guys say it's an amazing flaring tool. I do have a snap on bubble flare kit that's made by imperial and I like it, imperial makes nice stuff. But if I had a choice between the 350 dollar imperial or 300 dollar hydralic mastercool I'm pretty sure I would choose the mastercool. Any reason you feel the imperial that costs 50 bucks more is better than the mastercool? Just curious if I'm missing something.
mtkst19
blitzburgh pa
if you do any serious amount of brake line or plumbing work, the mastercool setup is nice. the an fitting adapter is about 80 bucks iirc. will flare up to -8 line. having the misfortune of re-piping a lot of cars brake lines due to rust, the mastercool setup is nice to have as opposed to traditional hand setup.
afazz
Pittsburgh, PA
I got the Imperial because it is capable of flaring thick walled stainless, the Mastercool isn't quite as powerful. Some of my work involves plumbing lowriders with hydraulics, where 1/2" .049" and even .065" stainlesss tubing is common. The Mastercool won't do that, the 400-F can with no problem.
After re-reading my post I made it sound like those 3 are the only tools worth buying, but really if you're only doing Aluminum tubing you can get nice flares with something much cheaper.
Group B
CT
I have the Ridgid 337 and it has worked flawlessly. I'm not sure about the design of the others, but the Ridgid rolls the cone on an eccentric to flare the tube instead of just mashing it down the center of the tube into the die. It works very smoothly and it also has a spring clutch sort of thing so you don't drive the mandrel cone too deep and bind up the tool. It looks like they updated it to have a ratchet mechanism now. I've been very happy with it.
http://www.ridgid.com/ASSETS/95C2E1ACFD8B4E039DCDEE467B0E073D/999-997-332_458R%20Flare%20Cat.pdf
http://www.ridgid.com/Tools/458R-Ratchet-Flaring-Tool/EN/index.htm
jride200
Careful... This is a 45 deg. flaring tool. You can't be mixing the two together.
Growwheels
Oregon
I got the 337 tool from a local tool house.... i couldnt get a decent flare with it to save my life. All of them were off center. And splitting. I thought it was user error till after the 10th attemp i scrutinized the tool. The die plates had the hole off center..... causing the flare to be off too. Exchanged it for a good one and this one works well.
Alfisti
Perth Australia
Try looking on Yardstore you may be able to pick up a really good quality used one for less than a not so good new one.
