ex-x-fire
Anyone ever see these? Too bad they didn't stay around.
Nope. Wish I had seen those when they were available. I would have bought both sets.Anyone ever see these? Too bad they didn't stay around.
Nope. Wish I had seen those when they were available. I would have bought both sets.![]()
Yes but at an inflated price compared to HF, I'm sure.OEM, sunex, Carlyle, GW and others make em
Reminds me of a chainsaw bar grease gun. Wonder if one would work.
By the way, what's the grease gun look like that is used for these ball bearing grease ports?
Is it a small little pump or is there an adapter for a full sized grease gun?
I used the small ones under 1/2 barrel planters, left outside until the plywood under the rugs rotted away. Then I realized that for $7.99 the casters and hardware were were cheaper on the dolly than bought individually. I got some fresh dollies and a couple of pressure treated 1x4s and built new ones. The pressure treated came out to just over 3 bucks a dolly so for $11 I have some plant dollies that should last a while. Plant dollies from the garden center are WAAY more. The casters don't seem to rust. The solid wood on the long sides should make some kind of shelf units.I have beat the **** out of both the large and the small ones. If you broke one it was all on you.[emoji481]
Maybe i just got a bad batch then. I used them to clean big tap shavings (3/4+) out of holes and the only one that lived is the straight pick.
Has anyone used a grinding wheel dresser from Hf about 5 bucks I was thinking about putting it on my list
Sent from my KYOCERA-E6560 using Tapatalk
Pass-
https://m.harborfreight.com/power-t...riable-speed-rotary-tool-kit-31-pc-60713.html
Bought this after my RTX rotory died in the middle of a project. Good power, and fairly hefty, has more weight than any of the Dremels I've owned. I'm just using it to cut some mosiac tile backsplash so it'll be just fine
I've been doing that for awhile. I like to use PT 2x4's because I use 'em for motorcycle engine cradles. You just have to size new carriage bolts.I used the small ones under 1/2 barrel planters, left outside until the plywood under the rugs rotted away. Then I realized that for $7.99 the casters and hardware were were cheaper on the dolly than bought individually. I got some fresh dollies and a couple of pressure treated 1x4s and built new ones. The pressure treated came out to just over 3 bucks a dolly so for $11 I have some plant dollies that should last a while. Plant dollies from the garden center are WAAY more. The casters don't seem to rust. The solid wood on the long sides should make some kind of shelf units.
whats everyones take the on Predator 4400psi powerwasher?
Limited 90 Day Warranty (Retail)
Harbor Freight Tools Co. makes every effort to assure that its products meet high quality and durability standards,
and warrants to the original purchaser that this product is free from defects in materials and workmanship for the
period of 90 days from the date of purchase
Here's my take on it...
$850 is a good price for those stated specs though. But other manufacturers give 3-5 year warranties on pressure washers. Not sure why HF can't seem to understand current warranties. For me the lack of warranty and lack of future replacement parts would make me spend a chunk of money like that more wisely.
And before someone brings up paying extra for their "extended" warranty. In the end you're just paying as much as a more credible product but your probably still not getting as long a warranty and again still not getting the replacement parts or product support on down the road.
HF's absolute **** warranty has made me realize that there is no value in the pricing of certain products.
Would be 125 to 150 bucks cheaper with that 15% off coupon going on. Not sure that makes a difference tho but good point. Just wanting something in that spec. Most I see are 3600psi and 2.5gpm.
It would be nice to know what pump they use, that is what you will most likely need parts for. I'm sure a replacement carb can be had on ebay for under 20 bucks. And any of the hose/gun/sprayer/fittings should be standard and easy to replace. Like I said, the pump and pump replacement parts would be the most concerning. It would **** to have to buy a whole new pump because you couldn't find 30 bucks in parts to fix it.
I read somewhere someone saying something about an AR pump. It was either USA or Italy made. Cant recall.
Professional-grade Annovi Reverberi™ triplex pump with brass manifold and ceramic coated pistons for exceptional life
https://www.harborfreight.com/catalog/product/view/id/13082/
Just a heads up - the latest round of HF coupons I received has a 25% off July 4 only and a 20% off good through September 7 that now are excluding Central Machinery items while the same coupons from another flyer does not. That excludes quite a few more items.
Damn, that's a lot of stuff added to the exclusion listJust a heads up - the latest round of HF coupons I received has a 25% off July 4 only and a 20% off good through September 7 that now are excluding Central Machinery items while the same coupons from another flyer does not. That excludes quite a few more items.
There's very little value in HF anymore. So if nothing is ever going to be discounted are they ever going to offer an acceptable warranty? Why not just pull into the Menards parking lot across the street and for about the same price get a 1 year warranty instead of 90 days.![]()
