An interesting six page ad for vises came up on eBay a couple of days ago.
the baby Prentiss jewelers vise has the pinstriping drawn in.
We’re gonna shake, rattle and roll
I said, shake rattle and roll
The only other "repair" I did was insert a .025 thick arbor shim behind the collar to eliminate some of the backlash in the handle. I couldn't quite get the pin behind the nut tight enough to get all the play out, but it doesn't move much. Pictures below of the finished vise.
Anybody out there know where I can get pipe jaws for this? I'll probably mock-up some jaws with wood or something to get the size down, draw it up in CAD and have my buddy machine a set. Heat treat is the issue though.
I explained poorly. What I meant was to replace the pin with a longer one, insert into hole and then use a hammer to knock the now long pin down towards the nut to affix it in place to remove the slop. Picture a bent nail in a board...
Make sense?
Another way to close the gap is with a spacer cut in the shape of the bottom of the nut.
A bigger question is "why is there a gap"? Wrong nut?
Mdkcal, are you anywhere near the shake and bake.---If you are, I'm thinking about you and all the fellows in the proximity.---My thoughts and prayers are with yaw.
A real nice restore on the Reed by-the-way, Mdk.
Probably one of several that was turned out under contract for some hardware line, so they could slap their own sticker on it.---Most all major vise producers did that some, at one time or another.
Dan, definitely a Wilton Tradesman 1740
Sent from my Moto G (5) Plus using Tapatalk
I think that a heavy top plate was a good call, it looks more substantial.
I never knew epoxy could look that good! Did you use JBWeld or clear?
I did braze weld similar damage on my Prentiss 56 (on this or the vise repair thread, I forget) and it took a TON of heat and I had to paint the slide afterwards to hide the brass color.
I’m running the So Cal Bull Dog rescue. I’ve got a 3” no. 263 hitting the door tomorrow, I can’t wait.
Maybe they can help with their shots, the needles keep bending. The 263 that I have coming tomorrow has a split base with the original wrench. I know your partial to those.PAWS will be so proud of you Smitty.![]()
Hanz and Franz will clamp you up
1. The 6” BesseyIf you had to keep only three bench vises from your personal collection what would they be?
