Caulking aggravation
Kaizen
New England
Finally painting my carriage barn themed garage. It has a lot of details and I’m caulking when needed. Problem specifically are joints from corner board to wood clapboards. Caulked under them so they smooshed into a bed of it and on top. Now six months later the joints show cracking. What am I doing wrong? Looks like **** and concerned with water penetration. This is the caulking I used, joint i'm caulking (some a little larger), the cracking, and an idea of the detail in the garage
fasteddie
If you put it on too thick it will shrink back as it dries. For big cracks, you should be using backer rod.
strutaeng
Dallas, TX
Yeah, that fast dry painter's caulk is no good, unless you are a production painter and "blowing and going" painting apartments that are going to be repainted in 6 months anyways.
The "Alex" stuff shrinks considerably over time. Use a better caulk. A sealant like PL mentioned is polyurethane, and much, much more difficult to apply. It also has something like a 7 day cure time, if you read the literature.
I would just use a better caulk. SW 950a is one that I've had good luck with. There are many better options out there. Dap Dynaflex 230 is pretty good too.
By the way, why was the trim not cut-in? Looks sloppy.
strutaeng
Dallas, TX
Actually, looking at the photos, it looks like adhesion issue...was the surface clean? Was it primed first?
Regardless, just redo the joint.
scottydosnntkno
Alex isn’t worth using outside. A good polyurethane like osi quad will last forever and not shrink and crack like that
K
Kaizen
New England
Meaning cut in with paint? That’s what I was going to do yesterday till I saw these cracks
K
Kaizen
New England
If I had large gaps I wouldn’t be worrying. These are small so I want them to not crack. I will get better caulk. How do you smooth the bead with those polyurethane types? Aren’t they very sticky? Normally I just use water
strutaeng
Dallas, TX
Water won't work. Acetone or similar. Make sure to wear gloves, and make sure to read about curing time. I recently had checked OSI Quad and it stated 7 days.
rayra
Escaped from Los Angeles
Problem is the best caulking really isn't paintable. Use the latex for ease of use and painting and anything thicker than 1/8" is gonna shrink and peel. Every time.
Blk88GT
Manitoba
I used that caulk on the inside and can also confirm the other poster's comments, it's junk. Shrinks, cracks etc.
rieferman
Collegeville PA (30 min west of Philly)
Good thread. I had the same experience around the interior side of windows where we caulked and then painted. At some point I'm going to re-do it, and will refer to this thread.
Go figure.... My thinking was that a product sold everywhere that literally lists all the features/benefits I'm seeking would be a good choice.
K
Kaizen
New England
Exactly. Not like I grabbed the elcheapo stuff. All vids I see painters doing used it. Figured it would be fine. Now trying to decide on least damaging method to remove. Guessing it will rip off primer as well. Nothing is easy in this build.
Dumber than lumber
That caulk you used is real **** IMO.
Caulk is a lot like tools.
Don't buy cheap tools. Don't buy cheap caulk.
They will cost you way more than you save.
The OSI Quadmax really impressed me.
2004.5cumminsman
Oregon
Is it rated for outdoors? I have trimmed three houses with DAP 30 minute, used for all base and cases not one issue? Don’t expect it to fill major gaps, and prep is key...
Buckaroo5
Central Ohio
https://www.wildlifecontrolsupplies.com/animal/SS900.html
This is what we used when I was doing vinyl siding for a living. Never had a call back for recaulking. You would have to search but it comes in virtually any color you want. If you have a building supply near you, ABC is where we bought ours, they can hook you up.
Don
This looks good. I want to apply it to painted/primed cedar shingles, masonry and flashing. It says it skims over in 1 hour and can be painted at that point - any experience doing that?
Buckaroo
bpjr
Florida east coast
Probably was put it on too thick for a single application. Most caulks give a max thickness on their instructions to control shrink and bead size varies depending on the product. Happens with many caulks whether cheap or expensive. Metal roofing guys usually know what the best caulks are.
K
Kaizen
New England
Perhaps. I'll be more exact this round. Went and picked up some `OSI quad max to try out.
Bert_
NW Iowa
I hate caulk. The only thing guaranteed is that it will fail, the better stuff just takes longer. Use it only when absolutely necessary. Tight joints and flashing work better.
Dadillac
Buckaroo
The majority of my experience with the Solar Seal is on new vinyl siding and trim. We did not do any painting. I also have used it on my own personal homes. I always buy the color I want it to be so I never painted over it. Solar Seal comes in more colors than Crayola has. Well maybe not that many. So whatever color you want it to be just buy that color. ABC Supply keeps in stock all colors of the siding that they sell. So most of the basic colors (white, blue, gray, almond, clay, etc and clear) you can walk in and out with. Special colors like red and green and such are special order and take a day or two to get. I would imagine most Supply companies do the same.
Don
Bert_
NW Iowa
Yup. Definitely need on wood clapboards. Mostly just concerned with lower part as there is a big overhang
Mine hasn't needed caulk for 90-some years :dunno:
A small amount of water will enter the joint. That's what the felt paper or house wrap is for. If you caulk you need to stay on top of it otherwise it ends up trapping water instead of keeping it out.
tonyciambrone
Northern Illinois
Alex plus is **** I will never use it again... causes me lots of aggravation with some trim projects.
Doesn't hold up on the interior and I imagine exterior is only worse.
K
Kaizen
New England
I’ve always been told it’s needed.the water will find its way to the silll and over years create an invitation to rot and termites. Just too many places that could go wrong for my comfort. I’ve replaced enough sills to know I don’t want to worry about it
Miss the Pontiacs
Saskatchewan Canada
This is bizarre:lol_hitti
Today I was caulking the truss ends in my garage. I got thinking as I was doing this project I should have checked for a thread on this subject for some additional expertise. I had chosen a Dap product that had some silicone in the mix. Don’t remember the exact name of the Dap caulking compound.
I can include a pic which has 4” of styrofoam and some expandable foam and then a gyproc plate with some drywall mud to fill in any voids and finally the caulking.
So then this evening I see this thread which would have given me some additional info. :lol_hitti
