lynn2323
I’ve been using a screwdriver without bit holder for sometimes. And the magnetic holding power is just too weak and the bits keep falling out. Therefore, I started looking for a new screwdriver with bit holder and came across this screwdriver on Amazon. The bit holder on it is just like any other screwdrivers. But is said it has some kind of elastic mechanism to relief wrist pain and add some elastic torque just like rubber band does. At first, I was really skeptical about it because it sounds gimmicky. But I thought why not give it a try and test it out.
The handle and the shank of the screwdriver is connected with elastic material, so it does let your wrist adjust in a certain angle. Since I don’t have wrist pain, I can’t say anything about wrist pain relief. However, it lets me do my job easily when I’m in an awkward position.
And about the elastic torque assist. As I’m testing it out, I found the elastic material stretches under torque pressure, and builds up energy like rubber bands do. Therefore, I find it easier to loosen tight screws with it. As when tightening screws, it only makes a difference if the surface is somewhat hard, like wood for example.
What I’m concerned about is the elastic fatigue. Because the elastic material is constantly stretching under pressure, it may fatigue in a matter of time, which I’m not encountering it yet.
Still a cool tool tho. And hope you guys enjoy the review and share some of your thoughts.
