Testing Out a New Screwdriver
lynn2323
Santa Monica
I’ve been using a screwdriver without bit holder for sometimes. And the magnetic holding power is just too weak and the bits keep falling out. Therefore, I started looking for a new screwdriver with bit holder and came across this screwdriver on Amazon. The bit holder on it is just like any other screwdrivers. But is said it has some kind of elastic mechanism to relief wrist pain and add some elastic torque just like rubber band does. At first, I was really skeptical about it because it sounds gimmicky. But I thought why not give it a try and test it out.
The handle and the shank of the screwdriver is connected with elastic material, so it does let your wrist adjust in a certain angle. Since I don’t have wrist pain, I can’t say anything about wrist pain relief. However, it lets me do my job easily when I’m in an awkward position.
And about the elastic torque assist. As I’m testing it out, I found the elastic material stretches under torque pressure, and builds up energy like rubber bands do. Therefore, I find it easier to loosen tight screws with it. As when tightening screws, it only makes a difference if the surface is somewhat hard, like wood for example.
What I’m concerned about is the elastic fatigue. Because the elastic material is constantly stretching under pressure, it may fatigue in a matter of time, which I’m not encountering it yet.
Still a cool tool tho. And hope you guys enjoy the review and share some of your thoughts.
BMack37
It looks like polyurethane which should take a LONG time to wear out.
mr.lemons
UK
I don't understand how the 'elastic torque assist' can be helpful but I haven't tried one. Interesting screwdriver though. Thanks for the write up.
L
lynn2323
Santa Monica
From what I've experienced, it builds up energy as you're rotating, then returns the energy back onto the screw. Which makes loosening tight screws easier.
CR888
Can you tighten the bit on? Is the bit holder a chuck?
bonneyman
Desert SW
Perhaps it works like those Makita Gold impact bits that "flex" in their mid-section while under load and then gradually apply the force to the fastener, thus avoiding strip out?
Anyway looks pretty cool.
Gotta link, OP?
L
lynn2323
Santa Monica
Gotta link, OP?
I've never tried the Makita bits so I can't say more about them.
But after a quick search, maybe they do have somewhat similar concept.
Link is below for your reference
https://www.amazon.com/gp/product/B07K1FV8B2/?tag=atomicindus08-20
L
lynn2323
Santa Monica
Hmmmm interesting design. I found a guy on youtube reviewing it, but it's sponsored tho. Hope it's not too biased.
Thanks for sharing the video! I guess the screwdriver will come in handy if you want to drill a hole but you don't have a drill? lol
Anyway, this video does show that the handle flexes to adjust angle.
M6erfan
'Merica!
LOL
I think he's trying to show that the screwdriver is easy to apply torque with it's "elastic torque assist", which I'll admit is quite impressive.
At the end of the day, it's a sponsored review.
You know what else easily applies torque? My M12 impacts/drills/drivers.
Just kidding. Sort of...
Seriously though, If I need that much torque, I'm going with a machine to save my wrists. Also, it looks like the diameter of that screwdriver handle is larger than my M12 drivers' heads.
jumbojak
Surry, VA
It isn't going to apply more torque than you could with your hand but I'll bet the spring makes a satisfying snap when it finally does break a screw free.
Robby321
Olympia, WA
Damn! Amazing ..NOT! Remember the 70's Lawn Mowers with the flip over handle, crank a dozen times, and slam it home, cranks the motor? Well one good yank ya rope start, way faster! SAME DAMN EFFORT DONE! PT Barnum was right.............( get a small LI batt hand drill)..
