Pipe thread question
paker
I need to drill and tap an aluminium casting (gear box casing) for gear oil drain port. Is thickness the determining factor? Since I cannot get 5 or 6 threads of 1/4" npt, I plan to use 1/8". What is your advice? Thank you.
gearhead1
NC
What’s the wall thickness? Should need around 3/8 or so for 1/8 NPT
https://www.engineeringtoolbox.com/npt-national-pipe-taper-threads-d_750.html
Also, don’t forget pipe threads are on a taper. So the more you tighten, the more ‘wedge’ you’re driving into the part. Think of it like a wood splitting wedge. As you go in, the force goes out. You could damage the aluminum housing if you go too tight.
So, yeah use the 1/8NPT for max threads. How much oil and how often does it get changed? 1/8NPT isn’t very big and will take time to drain. If it’s a lot of oil or a lot of changes, I’d go the weld a bung route and go as big as I could stand to make oil changes faster.
bwringer
Indianapolis
I would ABSOLUTELY NOT use tapered threads here. Great way to crack the casting.
There are skrillions of oil drain plugs hanging on the wall at your nearest auto parts emporium. Pick one with reasonably fine threads.
matt_i
SE Michigan
A 1/8-NPT is 27tpi, so the threads are fairly fine imo. Classic drain port for so many industrial gearboxes.
The judgement call is on whether the "wall" can handle the wedge/hoop-stress of the tapered pipe thread.
There is the route of going to an annealed copper or other sealing washer, design an o-ring face seal. The annealed copper is sold at my local Ace.
Welding is OK but if this is an assembly, some percentage of the oil that wets the innards, is going to "coke" into hard destructive particles due to the mega heat. Welding an oiled casting is not a good recipe for success especially if you've run into oil contamination with tig welding and the solution is usually to use oxyacet to burn-off the oil so the casting can be cleaned, also leading to more "coke". Also very bad if grease-lubed bearings get enough heat to "coke"....
Tapping isn't perfect either as metal chips can get involved into places you don't want them but there's always the route of washing them out. Coked oil is a time bomb imo, no telling when its going to let go.
MattT
That would work well if the OP is able to spot face the casting. That'll require a rigid setup and drill press at minimum but preferably a mill. Not going to work if he's planning to use a drill motor.
Keithinsc
Sandhills of SC
I will second the opinion on NOT using a tapered thread. Wedge action of the taper is too easy to crack something. Cast iron, I might be tempted though.
Tap it to fit a motorcycle type drain bolt, and use a crush washer.
Falcon67
Merkel, TX
FWIW - Early C4 trans cases (Ford - 1970s) use a 1/8-27 NPS thread with an o-ring. The case has a slight boss, with the threaded port and a taper where the o-ring seats. Hand tight they will seal 30+ PSI air. .250 inch wall probably not enough for threads and a taper for an o-ring. For a drain plug, NPS plus a sealing washer may do it.
People that are lazy or maybe don't know better have used 1/8-27 NPT type fittings and have managed to crack the case at the boss. Some get away with it, some don't.
kbs2244
I would go with 1/4 x 20
straight, so no wedge cracking concern
not very fine thread count so less of a stripping worry
a ton of bolt type heads to pick from for the plug
Wrench97
Southeastern Pa
Biggest hole as possible to get the oil and debris out as quickly as possible nothing like having to stand around for 20 minutes waiting for 1 quart of oil to drain out :)
fsae0607
San Fernando Valley, CA
That's what beer is for :beer:
To the OP's point, I'd likely use a reasonably-sized drain plug and sealing washer. I agree that the case could crack with NPT threads.
BillK
Beautiful Southern Maryland
Paker,
How thick is the casting ?? Unlike the others I would have no problem using a NPT plug. Unless you have no self control when tightening the plug I cannot imagine breaking the casting. 1/8" pipe is awful small for a drain plug. I would use 1/4" pipe. All it needs is a few threads.
Thats my opinion,
P
paker
My apology for a late reply. The gearbox is a small transfer case in a car without a drain hole. The unit is sitting next to a catalytic converter and exhaust pipe. Even with heat shields, the transfer case oil becomes a black goo. Premature failures at <100k miles have been reported. When opened, black oil with fine solid suspension reduced to 1/2 of the original volume.
The transfer case has a vent and a fill hole (1/4" npt). Draining through the fill port was a pain. I did it once and am determined to add a drain hole. The same car is allegedly sold in the Middle East with a drain hole in the gearbox. For your reference, the repair job costs $700 for the part + >$1000 labor.
I don't have the skill or tools to remove the transfer case. So welding a boss is not a practical solution. Some brave owners added a 1/4" npt plug. Based on their photos, not even 4 threads, 3 threads max. That's why I am considering 1/8" npt. Since I am the only person who will use the drain port, I am not too concerned about cracking from over-torquing.
Between 1/8-27 npt and 1/4-32 (or 28), which would you recommend? Thank you.
SGKent
Citrus Heights CA
what kind of car?
The Cobbler
I would be inclined to use a bolt with fine threads & a sealing washer like used on oil pans . that way you don't have the worry of the taper putting outwards pressure on the casting.
even get a replacement common thread drain plug & tap the casting to that
claymont
CLAYMONT, DE
You only need a couple of threads (3 or 4) in the casting to hold the plug in. Since its tapered, it'll lock up nicely. You're not going to need a lot of force to hold this plug in place. Loctite makes a thread sealant with a thread locker that works well.
Measure the bottom of the plug and mark that on the tap; go two turns more and check plug depth. Adjust tap depth to suite your required plug depth. Leave a few plug threads proud of the case to allow for expansion of case threads when you remove and reinstall the plug if you over tighten it.
Loctite 483629 Thread Sealant - High Performance, 1.5 Fluid_Ounces
eBay item number:
192414301522
