454ragtop
Had a pretty good day at the flea market today, after a bit of a dry spell around here. Found this Stanley Bailey #7 plane, not something I would normally pickup, but it was in such nice shape, and a prior owner thought it was special and built the case for it. Check out the leather latches, pretty neat. One of you plane guru's will have to enlighten me as to what it actually is, not my area of expertise. Small amount of light surface rust, should I wire wheel it, or leave it for the next guy to decide how he wants to deal with it?
Found the PI 50-230 ft.lb. split beam torque wrench and the Snap On tune up kit. Some of it is a little rough, but it's all SO other than one of the 3 feeler gauges, which is a Mac. I was surprised to see those little pliers are SO, thought it would have come with a small pair of channelock type slip joint pliers.
Little Athol clamp on vise, probably would have skipped it, but it being an Athol, and as minty as it is, I grabbed it. Bunch of other smalls. most self explanatory. The little adj. is a 4" Williams Superadjustable, and the Prot obstruction wrench is 7/16" X 1/2", never saw one that small before.
The Reed Utility vise ended up being a bummer, didn't notice the weld down the side of the static jaw till I was just taking the pics. It's really well done, but it makes it a parts vise as far as I'm concerned. Off to the vise parts swap thread it goes.
