Kent_B
MI
Saturday replaced the straight pipe on the tractor with something shaped like a muffler. Funny thing, it isn't much quieter.
Sunday helped my son pull a motor on his project car.
Ben Buck
S. W. Ohio
I found my 10 MM sockets !!
2 deep six point 3/8 drives, while trying to get several sizes together for our new place in Georgia.
Went into the attached garage rummaged thru the wive's tool box, found my 10 mm short 6 pt. socket !1
All is well at the Buck house !!!!
meboatermike
Southern Maine
Not exactly in the garage, but removed old rusted metal bulkhead stair stringers (would have said ripped them out but wasn't enough good metal on one side to justify saying that :shocking: ). Son got after me the last time he was home about their crookedness and questionable safety :wtf: but he was right.
Installed the new galvanized stair stringers that I had shipped in from the mid-west last week (they were $ 30-40 cheaper than my local big box store which would have had to order them anyway).
Now I have a set of solid and level stairs again. :thumbup: These should out last me, the previous set were used 2nd hand to begin with 30 plus years ago.
Got pissed off at Rustolium again!:
I finished painting the stove box and less than an hour later gave it a second coat (did the same thing yesterday 3X!)
Box is fine, even on the front that was painted 24 hours before.
The effing lid crinkled on me, (and not even consistently!) :wtf:
Second time Rustolium has done this, last time with with clear coat following their directions to a Tee... AND its all the same can of paint...
Lid shots:
Body, no issues here!
Burner assembed after paint:
This corner I had to build up the foot with weld (did that on top of a brass piece and welded almost 1/2 the ring with a MIG)
Close up:
And the secondary burner end with the Bronze plug holding the valve assembly (bad pic not very impressive in the available light..)
kaymccampbell
Upstate New York
If you run the exhaust down and out towards the back, putting the muffler under the rear axle, with a little down turn on the end of it, your tractor will be quieter. It's what I did to my TO-20 to shut it up.
jmhinkle
Portland, OR
Did the front brakes and brake fluid flush on my daughters' 2016 Mazda6. Finished the parts painting on the Reed Vise in between wheels. Painted the words on it at the end of the evening.
bmxdad
Puyallup, WA
Replaced a bad rear Hub assy on the DD. Had to get the puller out because the inner race was almost welded on ... The 30-minute job turned into a 2-hour ordeal !!
outdoorspace
I found one article, which describes how to reanimate the old spark plugs, spent half a day, but did not work out, eventually ordered new ones on this link. It turns out that I wasted so much time on this...
d.mcfarland
Western PA
I've stopped using Rustoleum because of their ongoing QC issues. Talked with them and they claim their paint has more "solids" than anyone else, and I absolutely agree but that doesn't make it superior.
I figure if I'm going to take the time to prep and paint anything I want the paint to come out as expected. Duple-Color has been amazing but is slightly more expensive, which is the only downfall versus Rustoleum.
I feel like Rustoleum's target market is the random people who just want to slap paint down heavy so it looks new for 6 months.
NUTTSGT
Northern Central Ohio
More solids my rear end.
I just painted a cylinder cap with their rusty metal primer. The stuff was so thin, you could see the metal through the primer.
I primed the cylinder itself with XO rusty metal primer.
EDIT:
I'll have to get pictures tomorrow.
d.mcfarland
Western PA
I wonder if their claim is for top coats and not necessarily primers. I know their self etching primer sprays very well compared to their color coats.
Shane6377
Replaced the blend door actuator in a Ford Ranger. Kind of a pain in the ****.
While I'm here let me open this up and see why the old one failed. Gee, I wonder if that has something to do with it?
Nice work. I did the same thing on a Chevy Traverse a couple of weeks ago. Mine was a tight fit too. Thought I was going to have to have my daughter help with her little hands!
bergheger3
Missouri
replaced the drivers heater channel, made a patch panel for the front inner fender and made a patch panel for the rear quarter in my sons 71 beetle. while he saved the door handles and mirror holes.
polexican23
burbs-Illinois
Did a color change (yes i know black is void of color) on some engine parts for the Vdub. (Dont zoom in, need to do touchups. Let the 2year old help and it shows)
Sent from my SM-N950U using Tapatalk
ezriderga
NW GA
On the 1st of every month, I check fluid levels, tire pressure etc, however since we leave early in the morning for a two week trip to Arizona and southern California, I did the preventive maintenance in my garage today.
NUTTSGT
EDIT:
Been a couple of days. You can clearly see the difference.
CoogarXR
Cut a couple pieces of MDF scraps I had to add a couple shelves in my wife's pantry. Funny, when we bought the house, there were cleats all up the walls for shelves, but no shelves...
So I cut some MDF. Got sawdust EVERYWHERE. Remembered why I hate cutting MDF indoors.
NUTTSGT
Well, today is not going any better than yesterday. Guess what I did in the garage ? Yeah dropped the ******* extension ladder and hit the John Deere rider.
CoogarXR
Last time I had my big fiberglass extension ladder out, I had it extended, resting on the gutter by the downspout. A friend stopped over, and I took a break. While we were chatting, it suddenly got very windy. I thought, I better go take that ladder down. Just then, the wind caught it, and it blew down, bashed a dent on the porch on the way down, then shattered on the ground. I hate ladders.
Magnum440d100
Indiana
Flushing an engine block before I put it into one of my trucks. Gotta get it to at least fire up and move.
LS6 Tommy
Northern NJ
That is why you tie them off at the top.
Tommy
PassnThru
Bowling Green KY
There is one thing I've learned over the years - the more I do the more things just happen.
It's a matter of percentages and odds.
It all more than evens out when I know how to fix it after it happens because i do a lot of things and learned something from each of them.
You know how to fix that hood. You already have at least two plans - you're just trying to figure out which one is best :thumbup:
Magnum440d100
Indiana
Got the motor set in there. I may have to move the drivers side motor bracket to behind the ears instead of in front, but that’s a tomorrow problem.
For now, it’s at least in there. I’m hoping that I can have it all hooked up and at least moving under it’s own power in a couple of days :beer:
Still need a good fuel tank, but I’ll run it off a jug for now, so I can tune it. I’m still undecided if I want to spend $200 on a tank for under the bed (gonna need some fab), or $300 for a stock replacement behind the seat tank.
I’m a stickler for originality sometimes...
