Cornwell ratchet id?
radnack
NY
Hi i was at a yard sale today and picked up a box of random tools for 7 dollars. I got a ratchet that really interested me. Its a push through cornwell ratchet i dont see any model markings on it. It seems to miss a few teeth. I was wondering if i could rebuild it? Ive always liked the push through design on the old ratchets. Any info is greatly appreciated! I havent even heard of cornwell before today! Pictures below! it is 1/2 drive
R
radnack
NY
Thank you for the model! Is there anyway to rebuild these? Do you think it would be worth anything to collectors being it kinds of skips teeth or not? I dont really have a use for it.
There isn’t a way to rebuild as they aren’t meant to come apart. There aren’t any teeth in a gearless ratchet. I’m not sure how it works, maybe a rollers and spring mechanism. Might try soaking in some clean ATF (automatic transmission fluid) for a while. That could clean the inside and lube the parts.
Cornwell stuff doesn’t go for very much really. Cool ratchet though.
bonneyman
Desert SW
Here's the internals of a Kobalt gearless rat for comparative purposes.
R
radnack
NY
Interesting design its to bad there's no way of taking this one apart. Not sure what to do with this one.
bonneyman
Desert SW
Looks like a pressed-in collar on the one side, so, not made to be disassemble-able. Just soak it in 50/50 acetone/ATF for a week and see if it frees up. I don't suspect you're going to put it in the work rotation though.
Jason280
I'd just drop it in a bucket of carb cleaner or Kroil, and see if it loosens up.
