gear oil transfer pump
aidank
Ireland
gentlemen,
looking for a hand operated pump for pumping gear oil 80w-90 from 20L drums into hard to reach places
anyone got any ideas?
I presume if it pumps gear oil satisfactorily then it will pump any type of oil gear oil being about the thickest there is
regards,
aidan
KnightFire
WV
I don't know if this will be of benefit or not; however, I use a hand held "Mighty Vac" when I pump from quart containers to differentials/transmissions.
It does take some time and it appears that you may need something that can deal more efficiently with larger volumes.
They have quite a few tools for fluid transfer, you might be able to find something that will work specifically for your needs: http://www.mityvac.com/
HTH
Shadowdog500
Down the shore
I use something like this. It screws right into the top of the bottle.
Chris
http://www.dsmtuners.com/forums/attachments/maintenance-repairs/101749d1255979788-how-do-u-put-gear-oil-my-******-adf-pump.jpg
Here is one for a 20L drum and link http://www.ferret.com.au/c/Alemlube...-the-8828-20-litre-gear-oil-drum-pump-n878133
tslabaugh
Oklahoma City
Alot of guys at work use an old honda power steering pump. Attach hoses to inlet and outlet, put inlet into fluid jug. Snug a nut onto the pulley shaft and use an impact to spin the pump to pump the fluid.
Iron-Iceberg
A-town
I like that idea THANKS!
rhandwor
Go to yahoo search hand pump for 5 gallon pail
Northern sells a lot of different types.
