Insulation under pad
g1teg
In my dreams
Hi,
Not sure if this should go in "heating and A/C" or in "flooring" or "general"...
Engineer spec are as follows.
"2" DOW SM INSULATION, CELFORT 200 (OR APPROVED ALTERNATIVE) UNDER 5" SLAB PORTION OF THE FOUNDATION"
"2" DOW SM INSULATION (OR APPROVED ALTERNATIVE) UNDER THICKENED EDGE PORTION AND OUT BEYOND THE EDGE OF THE FOUNDATION"
I am having a hard time locating the C200 requirement locally. Should I be looking for some other name?
Thanks!
HoosierBuddy
Southern Indiana
When faced with the same issue (could not find the proper foam at my local big-box stores), I was able to source the proper foam from the concrete company. They had everything I needed.
So...give them a call. Mine had the mesh I needed to tie my PEX loops to as well. So I had them deliver it at the same time.
Phil
G
g1teg
In my dreams
Celfort 200 is just 2" thick XPS insulation. Formular 200 is the same thing.
So why the different callout by the engineer? I was told by him that the C200 is for high pressure applications, where the other 2" is cheaper and can be used outside the underneath of pad.
G
g1teg
In my dreams
Phil
Thanks Phil,
I'll definitely be doing this, I need them to deliver some 6x6 WWM too, hoping I can get them to send 20' lengths!
Thanks for the tip
G
g1teg
In my dreams
Thanks all,
local insulation company had C-300 so I went with that. Less than half the price of a sheet at Home Depot... if I could even get it!
