Question about different PVC wyes (plumbing)
aunsafe2015
Northern VA
I'm adding a utility sink to my garage. I need a 3 x 3 x 1.5 wye to tie into an existing 3" drain line.
In terms of shape and size, both of these appear to be what I need:
https://www.lowes.com/pd/Charlotte-...n-dia-PVC-Schedule-40-Hub-Wye-Fitting/3132805
https://www.homedepot.com/p/Charlot...DWV-PVC-Wye-Reducing-PVC006011200HD/203396271
The wye in the Home Depot link seems to have some sort of perforated edge at the 1.5" opening, whereas the wye in the Lowes link does not appear to have the perforated edge.
Can anybody tell me what the difference between the two is, and why I would pick one over the other?
I also note that the two items appear to have a similar (if not the same) model number, so perhaps they are identical items and the Home Depot link is just a weird picture?
Thanks for any input.
rlitman
Long Island
The picture isn't weird. The HD wye is built around a 3x3x2.5 mold that has a bushing cast integrally into it, while the mold for the Lowes version is the actual size.
I don't know why it would matter though.
rlitman
Long Island
In other words, you're not aware of any particular reason to select one over the other? They are basically interchangeable?
That's how I see it. Unless maybe the bulkier collar interferes with the fit somehow (though I can't imagine how).
edit: Now that I'm looking again, the Lowes fitting is Schedule 40, while the HD is DWV. I still think either should be fine for your purposes, but the Schedule 40 may be a little stronger.
K'ledgeBldr
Johns Creek, GA
First, you have the wrong fitting. What you need is a "sanitary tee".
If I understand correctly- you have a 3" DWV (vertical), and you want to tap that with a horizontal run that will go to a sink? If so, yes you need the sanitary tee- it's all about the venting. A wye used in that configuration restricts air movement for venting.
Also, depending on the size of the sink AND the run from the sink to the DWV- you may require more than 1-1/2" drain.
A
aunsafe2015
Northern VA
The section of 3" drain pipe that I will be tying into is white schedule 40 PVC in my crawl space, and it is actually horizontal (with a slight slope, of course). In the attached picture, I would probably plan to tie into the longer solid unbroken piece of pipe at the right.
The pipe I will be tying in will be a 1.5" pvc drain pipe from my sink. It will be coming from the rim joist area shown in top left of the picture (where insulation is), and I could actually route it so that I tie into the existing 3" drain pipe from either a vertical position or a horizontal position. It looks like horizontal would be easiest in terms of avoiding obstructions. The sink will literally be on the other side of that wall, so the entire length of piping from the sink to the 3" drain pipe will be about 6 or 7 feet. My easiest option for venting is an AAV (code allows them in my area). Due to space constraints I was actually thinking about trying out a trap vent: https://ipscorp.com/plumbing/brands/studor/trap-vent/.
With that extra info, do you still think a sanitary tee is better? This one would meet my PVC size requirements:
https://www.homedepot.com/p/3-in-x-...-Sanitary-Reducing-Tee-C4811HD33112/100346965
I could reasonably easily do either a sanitary tee or a wye. I just thought a wye would be somewhat smoother flow of the grey water into the 3" pipe, and it will also be a little easier to tie my 1.5" drain pipe from the sink into the angled wye rather than the ~90* sanitary tee, but I think I could probably manage with the tee if that is the better choice.
LS6 Tommy
Northern NJ
X2. Functionally, it doesn't matter, but as previously mentioned, you need a sanitary tee and the drain should be 2" minimum.
Tommy
K'ledgeBldr
Johns Creek, GA
If that's the case, use the wye. But with that length I'd run 2" to the sink then reduce down for the trap and AAV.
From the link that was added in a previous post- you should see why you use one over the other in certain circumstances (the reference term "laying on its back" gives a good indicator to how it works or doesn't work).
A
aunsafe2015
Northern VA
Yep, I saw that link and it was a good explanation. Thanks.
scottydosnntkno
The Home Depot one is made using an insert in the mold, so they can mold 3x3x2.5 3x3x2 3x3x1.5 etc from the same master mold.
It’s not perforated, it’s just ribbed for strength. That much solid plastic would have huge sinks/warpage as it cools.
Either will work. And the ones at your store might not even be that particular manufacturers (pvc is a commodity usually made relatively locally to where it’s sold) so different states can have different suppliers
stokefire7
Home Depot has a bushing in the branch. I'd run 2", at the transition to your trap arm , a 2" 1/4 bend with a 2" x 1 1/2" bushing and no AAV.
LS6 Tommy
Northern NJ
If that was done in ABS when the building was built, it's new enough that it was a violation.
Tommy
stokefire7
aunsafe2015
This combination waste and vent system is code compliant for your area.
A
aunsafe2015
Northern VA
aunsafe2015
Thanks. Got any more pics of a similar setup? My plumbing experience is limited and I'm not fully understanding what you are suggesting.
Edit: is the concept simply that if you use a waste pipe that has a large enough diameter, that you don't need a separate vent for the sink at all? And that the sink effectively uses the vent for the larger horizontal waste pipe that the 2" sink pipe connects to?
So I'd have my 1.5 in tailpiece and 1.5 trap, but I would go from the trap arm straight into a 2" waste pipe? And no aav necessary with that setup?
stokefire7
Thanks. Got any more pics of a similar setup? My plumbing experience is limited and I'm not fully understanding what you are suggesting. This gives you another option.
Yes, theory being , increasing one pipe size larger, will allow equalization of positive/negative pressure. The fixture IS vented. Third question is , yes.
Yes, I have another set up like this on my basement Lav.
