tslabaugh
has anyone tried the 2-ply Nitrile gloves?
Worth buying?
They aren't the most durable...but if you get a coupon and stuff, I'd buy them again. I'd give em a PASS.
Worth buying?
New to the forum but I have to give my HF input.
First off are my GearTech ratcheting wrenches. Double PASS.
These are absolutely indispensable and I don't baby them. I've used hammers on them, stood on them, and even used my floor jack under the 19mm. Almost had the rear end of my Suby off the ground before the bolt broke loose, amazing. They are the first tools I reach for even though I now have a full set of Blue Points.
Those wrenches sound great, thanks for the write-up. I am trying to find them on their website and I am not sure which ones you are referring to. Do any of these match?
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=95552
I use that exact same hand pump and have had great success. It doesn't work as well now though, but that's because I used to clean it by running straight acetone through it.+1 REALLY JUNK FAIL
FAIL Multi-Use Transfer Pump- aEpic Fail
http://www.harborfreight.com/cpi/cta...emnumber=66418
5 HP, 60 Gallon, 165 PSI Two Stage Air Compressor
I just returned this big smoking turd last night . Dont waste your time bringing it home. I made a whip for it and plugged it in ... nada ! Took it back apart and their ground was broken off the terminal . No biggy I fixed it , and plugged it back in . It started up in the off position . I unplugged it and pulled the cover and the plunger on the pressure switch was stuck . Again no biggy , so I cleaned up the piece of plastic that was preventing it from operating correctly .
So all is fixed and I let it run with the drain open for a little bit to break in . After a few minutes I closed off the drain to let it come up to pressure . After closing the drain it was still hissing . I find where the pop off valve is supposed to be and temporarily plug it to make sure everything is now operating correctly .
It comes up to full pressure and I can hear a psssssttttttt noise . So I start chasing down the leak ... after a minute or so I find it . The weld for the bung was leaking . Needless to say I let the air out of it and returned it .
I had read the reviews of this compressor and decided to buy it . I regret wasting my time and I am going to get a Quincy tomorrow . I will approach any harbor freight purchase with caution from this point forward as I value my time more than the potential savings .
Should of just got a new one. Unless its changed that compressor has an American made Baldor motor on it [not sure where the tanks are made]. You wont find anything comperable without spending hundreds more. Many similar compressors in that spec and price range have either a chinese or mexican motor on them. Good luck but i'd give that a second chance, not like other companies dont have their share of problems. Just my 2 cents.
They didnt have another one , and truthfully I wouldnt have taken it if they had . The electric motor was an AO Smith made in Mexico , not sure on the tank as I looked for a "made in" tag and there wasnt one .
With the issues I had with a "new" compressor from them its worth more money to me to get one I just plug in and change the oil in .
Aren't all pressure vessels required to be ASME labeled?
I don't think I would buy a compressor without testing/compliance proof of the tank construction.
I thought that it would have a welded on tag , but there wasnt one . And the stickers didnt say where it was made .
Has anyone used/bought this trans jack? Any good? Any coupons?
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=33615
So this is a PASS!!someone asked about the pliers, i had a set of channel locks style, slip joint pliers and needle nose. they were good and tight in the beginning but i bent the handle on the chanels with too hard of a squeeze. and all three got sloppy way to fast i have had my craftsman and klien tools way longer used way harder without them getting sloppy. so they get a fail
13 Piece 1/2" Metric Deep Wall Impact Socket Set Item 34683 PASS
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=34683
I'd definitely give these a positive review as well. I got the 66054 metric set a couple of months ago and have used them just about every day since. The color coating has worn off some on the ends of the wrenches, but they're all still 100% functional after quite a bit of abuse.6 Piece SAE Color Combo Wrench Set
Epic PASS!! I have these 66053-0VGA and the metric set 66054-0VGA and honestly probably use them more than any other wrenches in my box. They work great and have held up very well to pretty rough use. Highly recommended.
Anyone have any experience with these? Gonna be on sale for $5.99 before 20% off so I figure they are worth trying out.
I have noticed that Harbor Freight's quality (or lack of) has improved over the years. I am wondering if their prices will be rising as well.
we have the pittsburgh bearing seperator/puller set at work, used it for the first time yesterday( been sitting for a couple of years)- pass so far
ITEM 93980-3VGA http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93980
