Definitely use 2 belts. Oil, use what it calls for.
Squeak is from the centrifugal switch for the starting windings. Normal. Don't put in too much grease, you'll just fill the windings.
I recommend a sheave-type pulley. They don't tend to wallow out and destroy the shaft like normal pulleys. Trade off is a bit more expense.
What is sheave-type pulley? How are they different? I checked them at Grainger and sizes about 7in go over $200-300
With a regular pulley it just slides on the shaft and clamps with a set screw or two, right?
A sheave-type pulley (or at least, that's what I've always called them) has two pieces. The bushing fits over the shaft and is split and tapered like a collet. The pulley has a matching taper and is bolted to the bushing. When it's tightened, it collapses the bushing clamping it onto the shaft very securely.
eg: https://www.globalindustrial.com/g/...q-d-bushings-h-j-series-113310?trackType=null
It's a better way but not required. If the price difference is too great, don't do it. I sort of doubt this compressor will be running 8 hours a day anyway.
Graingers will **** your wallet no matter what you buy. I would call a local motor shop and see if they have any pull-off pulleys from junk motors. Worth a shot at least.
Edit: I priced graingers solid pulley at $221.
At mcmaster you can get a 7.15" cast iron pulley with bushing for $88+ s&h. They only sell "bushing" type in your size.
https://www.mcmaster.com/6209k129
https://www.mcmaster.com/6086K318
Thanks a lot! I also digged in, found some other sources. Example
https://www.ebay.com/itm/Cast-Iron-...657878?hash=item4435a31b16:g:DN4AAOSwP0tcmPa-
8.25 will spin pump to 950 RPM Will it be to high? I feel like spinning pump at min 700RPM is probably not the best idea.
I don't have any input for you there, sorry. The faster they spin the more heat and stress created, the slower, the slower the air is made. A lot of other users chimed in there, I'd suggest re-reading some of the earlier posts or contacting the manufacturer.
Here are the specifications for ABAC pumps including your new T39:
https://www.mastertoolrepair.com/images/Pump and Unit Specs.pdf
Maximum RPM for a 5HP motor is shown as 960, so I'd go with that or a bit less. You can also dial back the on-off pressure range to something like 130-155psi.
If you look up "grenaded" in the dictionary, those will be the picturesI retract my previous statement. That thing is scrap.
if a taper fit be careful on how much you tighten it.
I bought a brand new compressor clearance at Princess Auto where the pulley had shattered .
I ordered a new pulley off ebay and I could see how easy it would be to over tighten it & split the cast pulley. when it's ample tight enough, there is still space between the pulley face & washer and the crank.overtighhtening easily could spread the taper in the pulley to point of failure . one day I'm going to machine a bushing so the bolt snugs up to it & the crank.
I don't know if it's taper or not, I think I read it somewhere. I do have bolt but this distance throws me off. Also, even if I wanted to move it, how? I can't just hammer it in, right?
My only guess right now is to snug it with a bolt as is and since this bolt left-threaded it won't come off. I can add some medium locktite as well
Yes. It's tapered, verified with calipers.
I don't think I will be taking it off, it's on good, don't see a point. But shaft is like 20mm in and bolt is like 25mm. So, I can get it snug with a bolt but wouldn't use much pressure at all.
5/8 OD is all I was able to find at home depot.
I used a HVAC bender. They also have those springy things that will support the pipe, might want to look at that.
Worse case, use a coat hanger to mock up the run, and have a shop make you one. It will save a lot of frustration.
I recommend compression fittings since flaring is another tool you would have to buy.
Finally got back to compressor. Took head off, found some debree, no big deal. But no rust inside, cylinders/pistons look new (as they are new). So, all is well, put it back together.
But for now I need to figure out copper tubing going from pump to a tank. I need to bend new one. Old one is 3/4OD copper. Looks like pipe (0.65 inside).
Question is: Can I bend pipe?? And can I use regular water pipe?
If I can't bend, can I solder in sections? Will solder joints hold 175PSI?
Don't know specs but did torque cris-cross to the same figures with 1/4 follow up turn on all of them in cris-cross. It will workDid you torque the head to specs? Being as it's aluminum, it's paramount that it is properly torqued down (in a cris-cross) pattern to prevent warping the head and blowing out the gasket.
Your old discharge line is copper TUBING not PIPE. If you are planing on bending a new one, you will need SOFT COPPER tubing, which comes in rolls. You can't bend hard copper (which is always in straight lengths) without annealing it first. Borrow or rent a 3/4Ø tubing bender to make the job easy.
Use compression fitting (easier than flare fittings) to connect to the pump and receiver.
You CAN use hard copper and elbows and solder, but with the vibration a compressor creates, I wouldn't recommend it for long term.
EDIT: The tube in your photo shows a compression fitting. All you need is new ferrules (the brass ring on the tube, you can cut the tube and remove and re-use the nut. Your HVAC buddy will surely have a 3/4" tube bender.
And I need to find 3/4 tube
Tubing is correct, you can use standard ferrules. Mcmaster # 50915K618
If you use the YOR-LOK ferrules, you'll need to use YOR-LOK nuts and fittings as they are not interchangeable.
