soloz2
I am in bad need of some new garage doors. my main garage has 3 old wood doors and I need to replace the two main doors so I can actually use my garage. Since I'm new to this I'm seeking some advice here. I have also come to realize that my doors are not exactly standard. The opening for the two main doors are as follows:
6' 8 3/4" high and 10' (80 3/4" x 120") wide for one and 6' 8 1/4" high by 10' 1/2" (80 1/4" x 120 1/2")
To compound issues, I have low clearance all around inside.
headroom: 6" (the current doors are a bit taller and I have 4" from top of doors to ceiling)
sideroom: 3.5-4" either side
backroom: this is the only place I don't have any issues. I easily have 15'
I asked 3 local companies to come out and quote me doors, but only 2 actually came and I wasn't thrilled with either. The better of the two quoted me CHI 2283 10' x 6' 9" windowed doors for $1510 installed each. T
The second company came when I was not home so I could not meet with them and they quoted me CHI 2283 10' x 6' 6" doors saying I had to frame down the opening myself prior to them coming. They quoted me $1300 each. This quote specified extension springs. The first quote did not specify torsion or extension springs, but I seem to recall it being extension springs.
It seems I can order Holmes doors from the local lumber yard in model 6200 Gold series w/ windows for $877.20, or step up to the 7130 series for $946. They did have lesser options as well. They said I could choose either extension springs or rear mount torsion spring. Either way, I know I need low headroom track kit.
I did also snag 2 of the clearance $99 chamberlain garage door openers and I plan to install them on the front two doors.
Here's where I'm torn.
1. knowing how little headroom I have would it be better to custom order say a 6'8" door or a 6' 9" door or should I just frame down to 6' 6" to give myself the extra two inches of headroom? This would net me 7.5-8" headroom, or almost enough for a front mount torsion but alas not enough.
2. Do I stick with extension springs knowing they will not last as long, but will definitely be easier to install and just plan to replace them mid-life cycle. or do I go with the rear mount torsion spring? I have heard rear mount torsion is not as good as front mount, but is possibly better than extension. However, rear mount torsion apparently requires professional installation?
3. Do I go with the 2" polystyrene style door in either CHI or Holmes with an R value between 9-9.6 or do I step up to the 1 3/8" polyurethane door with an r value of 12.9?
4. Do I replace both doors together, or one this year and one next year? I'm leaning towards both this year as the one door is quite rotted and the second has decided to get caught on the opening and now requires 2 people to open.
I hope I have explained clearly enough my plight and I eagerly await the advice of the gurus. Also, I know I could remove windows to shave costs here, but I would really like to keep windows as I have windows now, and I do like to detail my cars so having a little extra natural light would be helpful.
