TT_Vert
I have an indoor LV transformer that will power some outside lights. Rather than put an AC box outside as well as the transformer I am going to put them in my garage. The transformer is indoor rated. I want to have the wire exit as low as I can as possible in the exterior wall and down into the ground but I also want it to look nice. Anyone have any suggestions how to trim the inside/outside to conceal the wiring?
Perhaps an LB like this into 1/2" conduit that'll go into the ground and be backfilled. Just not sure if there is some weatherproof box I could use that i could screw the LB into or if there is another aesthetically pleasing way to get the LV wire from it's exit hole down into the ground. I "could" use a feed through bushing but then I have the wire exposed which I won't like the look of. I also could use a wire guard there but that would look unfinished to me IMO. Perhaps i could 3D print a cap on it and paint both the same color as the wood siding.
On the inside I will probably install an old work bracket and probably banana jacks. I'll then put banana plugs on a whip that will feed into the transformer to make the inside look nice.
Dave
Dave
