threeputt
I got my old Weaver 432 compressor ( 1962 year ) going and plumbed it to a 60 gallon tank. It works great but over the years people have messed with the pressure regulator valve setting.
. I have it set at 120 psi to cut out and it works. Not sure what pressure it should kick back on ? It is now cutting back on at 40 psi which I think is low. There are two adjustments under the cover I made the red mark on. One is larger than the other so assume that is cut off setting and the smaller one is cut back on ?
Can anyone recommend a regulator to install on this ? To be honest its never had a regulator since 1962.
My compressor is being run by the original 5 hp 3-phase motor. It is old like me and I want to make sure it out lives me
Any suggestions welcomed.
I have three new 90 inch belts installed now. Not sure how tight they should be ? I was reading tonight here about over tightening the belts.
