ZMotorsports Shop Projects 2.0
Z
zmotorsports
Northern Utah
I don't think that's possible :lol_hitti Must be some kind of sorcery.
I'm not looking forward to that part on my JK.
If you buy a complete suspension system and your Jeep is "typical" for what they designed the system for then the bump stop extensions are usually pretty close but still on the conservative side. IF your Jeep is like ours with pretty much every component altered or changed and a lot of weight added then you pretty much will have to pick a starting point and sneak up on the ideal setup from there. Yes it can be done but it does take some time if you want it exact.
For example, when I first lifted my Jeep back in 2011 I purchased the BDS 4.5" long arm system and it came with 3" bumpstop extensions for the stock D44 housing, that was running 35" tires. I never did hit my fenders or any suspension components in those years.
Now after many more alterations and still around 4.25" of overall lift and 37" tires my final setup is sitting at 2.25" of bump stop in the front and 3.5" in the rear with absolutely no rubbing, but it is quite close. My front actual bump stops measure 3.125" but the Dynatrac ProRock44 housing has a flat spring pocket and they come with a .880" puck to get it to stock height. So I removed that .880" puck and machined one bump stop measuring 3.125" which equates to approx. 2.25" over stock for bump stop extensions. I also have had to trim my front bumper back a little and reform my rear inner fenders but it clears the 37" tires with less bump stop than I did with my 35" tires and the bump stop extensions that came with the kit. I am not willing to get into cutting body or any major surgery to run less bump stop so this is where mine will live. Also worth noting, when I finally gave up on BDS's poly joints and built my own suspension links I put a bit more bend in the front lowers to allow more clearance for when I went to 37's because I would see that tire contacting the lower control arms was a common occurrence.
Just think it through systematically and you will minimize the amount of times you need to mess with the bump stops. Also, if you haven't already seen them, Synergy makes a very nice set of bump stops that snap together in 1" increments allowing you to make changes in 1" increments without having to remove the springs each time. I have used them on a few Jeeps but I ended up machining my own bump stops and I wanted to get it closer than using 1" pucks.
Z
zmotorsports
Northern Utah
I think your son is a chip off the ol' block; his Jeep looks as clean as yours! Can't wait to see what's up next.
Thanks Cam. It's nice to see his vehicles clean again. There for a few months after he bought his house and was getting ready for his wedding I was getting concerned because they were being neglected. My wife told me not to say anything because he had a lot going on but he managed it and came back to earth.:beer:
jeepinerdeep
South Central PA
I have a stack of aluminum Rokmen pucks leftover from my TJ in the shop for just the reason you described. Hopefully I'll get it with what I have, if not I'll check out those Synergy's you mentioned. Thank's for the tip, yep I'm waiting for fenders and tire so I only have to do this once!
lilscorpion
Colorado
Thanks for following along Matt and I hope I answered your questions to your satisfaction. Sorry if I rambled a bit but I wanted to convey as much information as possible and as detailed as possible so it would at least have some value.
As of right now I don't think there is anything I would change and just want to drive the hell out of it. I actually talked to a couple of people about doing LS swaps in their Jeeps but doubt I'll hear back because you know how people like to talk and very few ever follow through.:headscrat
Awesome! Did the spring rate increase noticably change the comfort on-road or off between obstacles? Can you remind us which fox shocks you have them paired with? Are they the smoothies? At first I thought they were a little stiff but after only a few short miles I realized that they were about perfect because the lower spring rate springs were allowing too much compression resulting in a soft or spongy feel to the ride. On hard corners/curves I was getting a bit more body roll than I liked also. Once I installed the new Metalcloack dual rate springs with the higher spring rate I quickly realized that it was much more sure footed having less "sponginess" to the rear of the Jeep and feels much more planted going into corners and/or tight curves. Canyon driving is a hoot now as I can actually accelerate through a curve and not feel like the rear end is squatting too much. It rides fantastic both on and off-road, much better than before.
Off-road I didn't hit my bump stops at all like before when going through a dip or whoop. The only time I got up against my rear bump stops was when crawling and slowly compressing the rear springs to full stuff or nearly full stuff. Also the couple of ledges I climbed up I had noticed that the Jeep didn't seem to have as much weight transfer to the rear like it did prior, but in all honesty the ledges weren't quite as big as the ones I experience in places like Moab so I'll be able to have more information after next months trip to Moab.
That's promising. I'm okay with being into my bumps when crawling its bottoming on the whoops and corners that drives me nuts. Excited to see how it does in Moab now.
As for shocks, I am running the Fox 2.0 non-reservoir shocks. Sorry I don't have the part numbers handy but they are the ones for a JKU with a 4-6 inch lift so I could get a bit more extension (droop).
Ok, cool. I had the same shocks (emulsion) on my XJ and loved them. At the time I got them because I didn't feel I needed the reservoirs but was admittedly worried that I'd be sorry. In the end I think I'm not using my jeep in a way that the reservoirs are necessary or if I am, I don't know how to tell that I am even in the whoops. Sounds like lenth-wise you're set up almost perfectly. Based on how you described them and my initial measurements, they could be either the 10" or 12" shocks. Are you running limit straps?
As for rubbing in the rear. When I cut my front pinch seams down in the rear fender wells I cut them a bit further than needed because I knew one day I would be going to 37" tires. I cut them and welded the pinch seam back together about 8 years ago to the point where they are almost perfectly flat with the inner fender. In the rear of the rear fender well, I did have to heat up and reform the plastic inner fender very slightly because during full stuff the tire was just rubbing the rear and I didn't want the tire to catch the edge and roll it under. I think I rubbed in the rear because when I built my control arms I shifted the axle rearward very slightly to assist in clearing the front pinch seam and may have gone just a tad too much. Right now at full stuff with the rear suspension I am clearing the front pinch seam by about 3/4" and the rear inner fender and bumper by about 3/8". Like I mentioned my control arms are adjustable but I built them when I got tired of continually replacing the bushings in the BDS control arms. I am also long-armed all the way around. I used Johnny Joints at the frame ends and OEM rubber encapsulated ones at the axle ends all the way around the Jeep.
Ok, well that makes complete sense. I've not yet gotten into the body yet so I'll need to plan on a little trim trim on the pinch seam. Man I hate cutting into the pinch seam. There's really nothing to worry about but in my age I've gotten kinda weird about rust prevention after learning to the extent that body shops (should) prep before paint when repairing areas like rocker panels where it's difficult to get things truly sealed. I view pinch seams just like those areas. Anyway, I'll cut it, it's what has to be done. I'll remember heating the fender trick too if I end up keeping the stocks. Super helpful, thank you.
Shoot, I hate hearing that they are wearing faster than expected. Mine have nearly 11k driven miles on them and about another 4k of flat-towed miles and still look very good for 15k miles. I did however get a little rock rash on two of my new Raceline wheels last week but I knew that would happen and it is pretty much unavoidable if you plan on playing in the rocks at all.
I mentioned this to my wife the other night and she's thinking that maybe I wrote down the odometer incorrectly. We're actively debating when I actually put the tires on. The difference would be 8k which might actually make the wear not so good. Another factor I failed to throw out there initially is that I didn't get my toe set correctly initial so I got so early wear on my fronts in the first 3 months. More I think about it, the more I recommend we both wait to see what you think for longevity..
LS swap is a non-trivial upgrade. Even the less complex ones like fenders and corners tend to have only a 30-ish% completion rate. Problem with the LS is it's a tri-fecta of commitment -
  1. $$$
  2. Time
  3. Complexity
Any one of the above can cause people to shy away. Two of them make it seem maybe too heavy to tackle. When the 3 of them finally sink in it comes down to what separates the bench racing from racing. I'll be honest, I'm not worried about the money (wife is), I'm not worried about the work or fab involved, I am a little concerned about the modern complexities of the new motors in which I have very little experience. I have a real example -
When installing the new steering box, I did research but somehow it didn't sink in the importance of locking the steering wheel in place. though I thought we had, somehow my son and I got out of alignment by a rotation and when cycling the steering, the clock-spring in the steering wheel broke and now nothing works in the steering wheel. Though I've not yet tackled a fix which seems fairly straight forward, I was reminded that my old way of thinking brain is what got me into the mess in the first place. I'm not super excited for learning a lesson with something as expensive as a transmission or a motor. I think I've just become more risk adverse in my old(er) age.
lilscorpion
Colorado
Slick, had not seen them before. Awesome share!
Z
zmotorsports
Northern Utah
What a great day working with my son in the shop yesterday. I’ve missed that lately.
Started by dropping the transmission pan.
Actually looks pretty good with very little sludge.
While everything was dripping off I machined a bung to be welded in the pan for the transmission temperature sending unit
Used my sheet metal bits to drill the hole once the location was determined.
Welded and painted.
While I was waiting for the paint to dry and while I had the welder out I fixed my 3rd hand and fabbed up a holder for my dust pan and small broom.
Painted.
Bolted to side of my cabinet.
Old trans filter and filter seal removed. Careful when removing this seal to avoid scoring the inside of the seal bore. I will install a prybar until it contacts the bore then back it off slightly to avoid damage.
Deep socket inverted to drive the new seal in flush with the bore. I lubed up seal as well as the filter and installed new filter.
While I had the pan off I also replaced the spin on cooler filter prior to installing the pan.
A small amount of dressing to hold the pan gasket in place during installation.
While we were looking at mounting the aux. transmission cooler locations my son noticed a small trace of coolant at the tank crimp on the radiator. We ultimately decided to replace the radiator while we had it in the shop. We also noticed a slight leak around the power steering hose at the crimp so picked a new one up.
Everything going back together.
More to come.
shortykorte
Tallahassee, Fl
Never heard of sheet metal bits. Learned something new.
You didn’t make several of those holders by chance? I’ll be working on a set for myself.
Shorty Korte
Always remember quality in QST
Z
zmotorsports
Northern Utah
Shorty Korte
Nice work on the Cherokee.
Thanks guys.
Sorry Shorty, I only made the one hanger that I was needing.:bounce:
Z
zmotorsports
Northern Utah
  1. $$$
  2. Time
  3. Complexity
I hear ya on multiple counts Matt. I feel the same way about getting into the bump stops. I was getting into them way to easily which is what prompted my latest spring upgrade. With two people sitting in the rear seat even street driving and hitting a pothole or going through a dip was contacting the bump stops which was unacceptable. Now I really have to be flexing off-road to get into the bump stops and the on-road manners are awesome.
As for the complexity of many of the mod/upgrades it can be overwhelming unless you brake it down into pieces. Twenty plus years ago I wouldn't have thought twice about cutting up a body for a little clearance but like you, I now worry about things like corrosion protection and wanting to keep things nice and rust free for much longer. Many people just say it's cutting and welding, nothing to it. While they are correct if steps are not taken to protect the exposed material it won't last long.
When I cut my pinch seams I liberally coated the inside with POR-15 and then rust through coating on the piece I was welding. Once welded I used seam sealer and then paint. Possibly overkill but I don't want to deal with rust and don't want to have to ever deal with that area again. Even at that, the amount I cut off was minimal, just enough to obtain the results I was after as I didn't want to cut any more than necessary.
Like the amount of work you have done and are doing to your son's LJ, people who haven't done it don't seem to understand all that is needed to have things work properly after modifying a system as much as that and especially when introducing non-OEM parts into a system. It requires homework/research and a lot of it.
When it came to the engine transplant I felt much better about combining FCA and GM systems only after much research and investigation. All of that research is what calmed my nerves and gave me the confidence to move forward. Swapping engines and so forth 20 plus years ago was a no-brainer but you have to think through multiple systems these days. Much like your clock spring scenario, one component can have drastic impacts on multiple others.
I actually show the clockspring replacement earlier in my projects thread here because mine went bad earlier this year or late last year and I had to replace it. All in all it's a pretty simple procedure.
jbmatth
Northern Ok.
I helped a friend replace the radiator on his Grand Cherokee, wow that was way more work than I expected compared to the GM stuff I'd been messing with previously. Did the trans pan already have a drain plug? That is one thing I try to add when getting into them if I plan to have the vehicle very long at all.
JB
Z
zmotorsports
Northern Utah
JB
JB, the radiator replacement was definitely one of the more involved ones that I have done.
The transmission pan did not have a drain plug but it does now as the sending unit will serve double duty. I feel the same way, if I plan on keeping it for any length of time I add a drain plug for the next time the trans needs servicing.
Thanks for stopping by and checking out what projects I'm working on.
Z
zmotorsports
Northern Utah
I’ve been trying to get my air bag recall completed on my Jeep but Chrysler wouldn’t allow me to take the part, replace it and return the old one to them. I tried telling them I will bring them the old one, video tape the replacement to prove it was done correctly and allow them to claim the work and get paid for it but I won’t let anyone work work on my cars. Last week they called me back and said they would allow me to go into the shop and watch the mechanic and asked if that would be sufficient. I agreed and today was my appointment. The mechanic did a great job. He was very nice and was very professional throughout the process.
Upon completion I thanked him and apologized as I know what it’s like having someone watch you while you work. He said he didn’t mind and completely understood why.
Dash cover removed.
Propulsion cartridge being replaced.
I really wish I could let go a little but I’m so uptight about things. Hell I didn’t sleep for **** last night just knowing I had to take it in to have the recall done today.
aka Larry
Eastern, NC
What's that big wavy line on the right side of the windshield Mike? I know it must be an optical illusion because there's no way you be rolling with a cracked windshield!
Z
zmotorsports
Northern Utah
You caught me, it's two big cracks. The I-15 corridor here in between Ogden and Layton have been torn up due to adding a lane for the past several months. I had been fortunate for the first part with only one small rock chick that I quickly filled at home that evening. However, the week before we were leaving for South Dakota a big rock came off the back of a dump truck and smacked the bottom of the windshield just below my wiper and above the cowl creating about a 2" diameter spot which basically destroyed the windshield. While we were in South Dakota the week before last it ran creating what you now see.
I am waiting until after our next Moab trip to get it replaced. All in all I really can't be that upset. This is the original windshield and I have 103k miles on the Jeep plus about another 30k of it being flat-towed behind our coach. I have had about 5 rock chips that I have repaired but none have run until this last one and being a Jeep with a very flat windshield I guess I should consider myself fortunate as I know many that have had multiple windshields replaced by now.
What ***** is I have one on my 2006 Duramax that I also need to have replaced as the one day I decided to drive it to work about 4 weeks ago it too took a rock impact and by the end of the day at work it had spread clear across to the passenger side from nearly center.:mad:
macgyver
Big Bear Lake
Dash cover removed.
I have been putting off the air bag recall for the same reason. I don't want anyone tearing into my JK.
Z
zmotorsports
Northern Utah
Tonight my son came by after work and we were able to get the aux. transmission cooler completed as well as the upper and lower radiator hoses installed and most all of the engine bay reassembled with the exception of the battery tray.
I fabricated three brackets to mount the cooler.
Mocked up.
Top of the cooler nestled right under the core support.
Brackets bead blasted, painted and installed for the last time.
I also installed abrasion sleeve on the transmission cooler hoses.
Thanks for looking.
Nlped
Hayden AL
Were trying to get my son’s WJ ready and sneak back down there towards the end of the month and test it out.
I ask because my dad & stepmom will be there next week and be there for 2 weeks. We are going to try and get out there the 2nd week. Guess we’ll miss you.
Z
zmotorsports
Northern Utah
Looks great as always Mike!
Thank you. I appreciate that.
I also just noticed that this is your first post. I am honored that you made your first post on my thread after being a member of the forum for 8 plus years.
We have friends there all month and after talking with the wife last night it looks like we are going to try to get there around the 12th or 13th. We'll be staying at the OK RV Park again. If you're still there please stop by and say hi.
Z
zmotorsports
Northern Utah
Mike,
I'm interested in your sheet metal drill bits. Would you tell me who makes them? Do you like them?
Thanks, Jon
Jon, the set I have I purchased from Lawson many years ago. I don't do a ton of sheet metal work but when I do use them they work slick. They cut the outer edge so nice and clean and the holes are actually round with minimal cleanup around the outer edge.
Thanks for stopping by Jon.
ttpete
Dearborn, MI
For sheet metal, I generally use Hougen Rotabroaches. They make a nice clean hole and are available in inch or metric sizes. I use brad point drills for plastics, mostly for motorcycle windshields. They won't start cracks like regular twist drills will.
Z
zmotorsports
Northern Utah
Agreed. I have the Rotacut annular cutters as well and prefer them for most jobs but I hadn't used these in a while and thought I would get them out and dust them off. In many of my previous pictures of when we were building my son's suspension on his WJ last year I show the Rotacut annular cutters in use. They sure make a nice perfectly round hole and fast.
ttpete
Dearborn, MI
I've probably cut thousands of spot welds. The advantage is that I can pilot it in a center punch mark and only go through one layer, then grind the buttons off.
Z
zmotorsports
Northern Utah
Yep. Back when I was doing a lot of paint & body work I wore several out cutting spot welds. They worked perfectly for that because like you said, you don't damage the bottom panel. It's an efficient way to cut spot welds for sure.
Z
zmotorsports
Northern Utah
Last night we continued work on my son’s WJ. We were able to pull a vacuum on the cooling system and while we had it sealed off checking for leaks my son installed the air box and I installed the battery tray and battery. After refilling the transmission and the power steering we took it for a road test before tackling the next job, a leaking front axle seal.
Before closing up the shop I pulled the front tires/wheels and drained the gear oil.
Z
zmotorsports
Northern Utah
Finished replacing the inner axle seals on the front axle of my son’s WJ tonight.
Carrier out.
Wear patten looks fantastic.
Wear pattern on the races and bearings looks great also.
Thanks for looking.
Z
zmotorsports
Northern Utah
We didn’t get as much done yesterday on my son’s WJ as I had hoped but we at least made progress. Again, the little details take time.
We installed his tire carrier that has been sitting on my shop floor for about nine months now.
While I was waiting for my son in the morning I added some stainless steel material to the Destaco toggle clamp for his carrier.
When my son showed up we installed the carrier.
Installation of the dust cap with my machined driver.
We installed the toggle clamp and welded a small tab on the clamp to locate a push pin.
The battery terminals were in pretty poor condition so we replaced them with some high grade marine connectors. We cut the original connectors off as the cables themselves were in good condition and crimped new lugs on with heat shrink.
Next task was to fabricate a license plate mount as now with an externally mounted spare tire the license plate is hidden if left in the OEM location. We used standard 1/2”-20 lug nuts which left about 3/4” of threads protruding. The plane was to machine some standoffs from 1” aluminum with flats for a 3/4” socket, the same as the lug nuts.
They were drilled and tapped with 1/2”-20 threads on one side and 8mm x 1.25 threads on the other. Then placed into my 6-sided collet holder in which to machine the flats.
Machining the flats.
One down one to go.
Standoffs mocked into place.
I cut a piece of 3/16” aluminum plate just a little taller than the license plate and drilled & tapped for the plate and LED light.
Before closing up the shop I ran a couple of wires from his right tail light marker circuit to power the license plate light and temporarily zip-tied the wiring until we can install the CB some time this week.
Thanks for looking.
LXCam
That plate holder is slick Mike, what a cool job you pulled off! Hey, we’re you source that hex C collet holder or did you make it? I’m always pulling out the indexing one for such tasks but I like the fact that one would be much quicker to set it up for an angled plane verses jigging up mine to a sine plate.
Btw, any issues with droop on the rack?
Z
zmotorsports
Northern Utah
Super clean! Love the details!
That license plate solution is awesome! Tire carrier turned out slick as well.
Thanks for the comments guys. I appreciate them.
Cam, the collet holder I purchased as a set. The set consisted of a hex and a square body as well as two knurled locking nuts and a quick release lever. I've had them for quite some time and can't remember if I purchased them from MSC or Enco. I'm pretty sure it was Enco. They are not a high end manufacturer but they are nicely ground and hold tight tolerances.
As for any droop on the tire carrier, none when we installed it. It barely touches the glide block that I put on the clamp end. I actually need to take mine apart and re-grease the spindle bearings and give it a tightening as mine is barely starting to droop with my 37" tire where it now glides up and over the glide block and it has been on my Jeep for nearly 8 years.
Z
zmotorsports
Northern Utah
We installed the CB in my son’s WJ tonight.
Installed the antenna and worked our way forward. Through the left tail light opening and along the passenger interior trim panels up to the center console where we installed the unit.
Thanks for looking.
