Recommend me a oscillating tool blade to cut steel
CalsXS2
I need to cut some exhaust manifold bolt's. Roughly 7/16'' dia.
I tried a couple of blades that I had on hand and it just instantly smoked them.
Had a friend say he likes Imperial, but never cut a bolt that big.
Can you guys recommend anything that won't break the bank. Thanks
dnschmidt
Phoenix, AZ
The answer to your question is: There are none. Dremel with an abrasive cut off disc is the best solution and you'll need several of them.
Minnesota Steve
Minnesota
I tried to cut a screw off with my oscillating tool and I smoked the blade fast. I'd say they work fine for soft metal like nails, but nothing hardened.
I'd ditto the recommendation of a dremel with a cutting blade on it. You might blow through a few of those as they wear fast and break off easily(that's why they come in tubes of 20), but it'll work eventually.
jumbojak
Surry, VA
Bosch makes a carbide metal cutting blade that will work. I have used on for to cut bolts before.
pbon
Use the ez lok metal cutting 1.5” discs if you can afford them. If you like creating dust, wearing blades out and unscrewing them and changing them, then the 50 pack abrasive blades are the way to go.
Parrothead
Earth
Firefighter1406
Bosch carbide tipped blades will work great for you. Have cut quite a few bolts with the same blade even.
nieuport17
I have had good luck with Diablo blades (for metal) from Homedepot.
If that doesnt work, like other have suggested, Dremel cut wheel.
bob15
Northeasten, CT
You can, if needed, cut steel with an oscillating tools. Used my Fein to cut the 1/2 bolts off my Case Vac's center clamp similar to the photo below. Difference between the picture and mine: mine was on the axle with no way of cutting it any other way (bolts on the case were originally rounded, carriage bolt type bolts).
I used the finest tooth count Fein blade that came in the kit and just took my time.
