This post will look at some aspects of the front of the shop during it's renovation from early, middle and current condition.
This has been posted previously and dates from the early 1970's. Notice the shop had two overhead doors across the front. At some point, man doors were installed on them as seen here. Also the electrical service was overhead which I changed to underground.
Here is a closer look at the right side man door which was the main entrance to the shop. The Briggs and Stratton sales and service sign was left on the building and it rusted away by the time I bought the shop. The Prestone Antifreeze thermometer was gone but I found it's twin in an old freezer in the 2 car garage that was in 100% perfect condition and I installed it in the lift room.
Here is the thermometer installed in the lift room. Looked completely new, had never been mounted before. It's about 28" high and is very accurate. The finish on it is porcelain so it would be durable outside.
This is a now well known image of the front of the shop from fall of 2005. The Briggs and Stratton sign is the rusty smug on the left and the large Johnson's Welding and Repair sign had faded almost completely away. Just above the power meter was the exhaust outlet for the exhaust fan to remove welding smoke.
One of two pieces of equipment I bought for the clean up even before I had closed on the property. I knew I would make great use of a chainsaw out there so I got a heavy duty one, a Stihl 16", commercial grade chain saw. The front of the shop is on the right and you can just barely make out the power meter on the very far right edge. We are just starting to carve out and free the shop here.
This of course is the other essential piece of equipment, the diesel John Deere tractor, here equipped with a bush hog. This was the first day on the property for it. It's sitting in front of the lift room door. Notice the bushes to the right. These were completely across the front of the shop obscuring it from the street.
Here enough brush had been cleared away so that the front of the lift room door is visible. The broken windows in that door let in rain water that eventually rusted up the rear chocks of the lift. The structure on the right side of the building was a storage area for sheet metal.
This is the car that replaced the family 1950's Studebaker, a mid 70's Chevrolet Caprice. My son and I were really hoping that it would get left but we were dreaming. A cousin wound up with it. It was in very nice condition. To the right of the sheet metal storage is a sheet metal brake.
This is a reverse view of that corner. Behind the tree and all around it is "stuff" I haven't cleared away yet. The tree to the left is the ash tree that had the chain around a limb.
This would be 2007 or so and I'm starting the landscaping work. Here cedar mulch is being placed to help control erosion on the slope and hold moisture in for the ground cover I planted.
A problem that surfaced was due to the family home having been physically raised up a couple of feet in the 1950's when a deeper basement was placed under it. That raised the grade to the east of the shop (right side in this picture).
See how much higher the Impala's are in the driveway compared with the Chevy II in front of the shop? When the shop was first built this was all level grade.
The problem that higher grade created was when it rained, all the rain water drained toward the shop. To divert it away, I graded a slight ridge along the driveway that would funnel water down the driveway ( to the right in the picture). I now had to find a way to keep the dirt from washing away right by the front corner of the shop where the sheet metal had been.
I built a small stone retaining wall to hold back the soil here and make the elevation change. To do the small wall and keep frost from pushing it, I had to put in footings, bury the first layer of stone and then stepped back each layer of stone about a 1/2 ". A water proof fabric was placed behind it also. In 3 years it's not budged.......yet! This is the spot where the structure that held sheet metal and metal brake used to be. I also put in stepping stones where you climb up to the lane which leads back to the barn. That's climbing ground cover that greens up in summer and browns up during winter. I planted it to prevent erosion. Stone was also used to create a small lip around the edge of the concrete to prevent soil from washing onto it. Seems to have worked.
When I had the barn floor and driveway poured last fall, 2009, I had the shop driveway concreted out to the street at the same time. This way the tire treads don't pick up small stones and then drag them into the shop. It was too late in the year to do any grass planting along the edges of the new concrete.
If you haven't tired of all this yet, I do have more on the shop coming......
Thomas
