superduty1
- Joined
- Aug 5, 2011
- Messages
- 234
I have a garage door that reverses just before it gets to the bottom. It gets about 2 inches from the bottom and reverses back up. It reverses probably 80-90% of the time and other times it goes to the bottom as it is supposed to.
It is a Liftmaster 8500 opener. I have double checked the door limits.
Garage door is about 5-6 years old. Professionally installed. I have 3 of the same doors with the 8500 openers. I called out the installer about 2 yrs ago for this problem and they said the springs needed adjustment. They adjusted the springs and the door actually worked for some time. I am guessing on dates, but a number of months after they adjusted the springs it started having the same problem again.
I recall the service guy said that the springs need regular adjustment or this will happen. The other two doors, installed on the same date, have never been adjusted and work perfect.
I am skeptical that this is a spring issue, but I am far from an expert.
I will add that if I pull / force the door downward as it nears the bottom it will go to the bottom and not reverse.
