TravelingLight
I've gotten a lot of great tips just lurking on this board, but it's finally time for some questions myself. Disclaimer: I'm sure I will use some terminology incorrectly, but hopefully it'll be enough context to understand.
I'm currently in the process of building a 12x20 shed, on a slab, 6/12 roof. I'm ready to start sheeting (sheathing?) the roof, but the rake ladders/overhangs are causing me some stress.
Some specifics about this build: This shed is permitted/inspected by my city, i.e., 2015 IRC. The roof trusses are engineered trusses built by people much smarter and qualified than I am, i.e., I can't notch them out. Nor did I get the gable trusses dropped/built lower to accommodate lookouts/fly rafters.
So I'm stuck with just tacking on the ladders to the gable ends. NOTE: I live in the deep south, deep enough that snow/snow load is basically non existent. Also, my overhangs are only 12". I've gotten one up, and it was a real PITA. I built the ladder entirely on the ground, 24" OC, and hauled it up there by myself, got it tacked on and have a temporary support on it for now:
This process isn't going to work for me. I'm building this entirely myself, so lugging a ladder up like that is difficult. So I had another idea, and I'm curious as to everyone's thoughts. Can I sheet the roof first, but hang the OSB over 12" to accommodate the ladders, then add the ladders by piece? As in, after sheeting the roof with the overhanging OSB, then add the back 2x4 (attached to the gable end), add in the cripple(?) studs, and then the front 2x4? And of course attach the OSB to the ladders as well. I hope, because this would be insanely easier on me.
Finally, I've framed out the structure using a framing nailer, instead of screws, because code. But can I/should I use screws to attach the roof OSB sheets? Seems like the general consensus is better strength/holding power with certain screws over nails from a pneumatic framing nailer?
Thank you all! I wish I would have found this board before I started this project.
