NewShockerGuy
I'm at the point in our basement that I am going to be doing the treads and risers via Cali bamboo vinyl treads and risers. On their site they recommend a "high-quality Urethane based glue, such as Titebond Fast Set Construction Adhesive. (Do not use liquid nails.)"
Titebond PROvantage Heavy Duty Construction Adhesive:
https://www.homedepot.com/p/Titebon...Vrf_jBx1RmgmqEAQYAiABEgLgffD_BwE&gclsrc=aw.ds
I was browsing for a good adhesive and Loctite came up and tons of reviews state this is what one should be using as it's better than anything out there.
Loctite PL Premium
https://www.homedepot.com/p/Loctite...Vef7jBx2PIgduEAQYAiABEgIi-fD_BwE&gclsrc=aw.ds
My question is since I've never used construction adhesive before I want to make sure it's correct. Is Urethane based construction glue the same as polyurethane based?
This is going to be used to bond the vinyl stair tread (entire tread piece) to the existing wood stair tread after I cut the nose off. The riser will be bonded the same way on the standard wood riser that's there now. I want something that the treads/risers never come loose or apart/wobble, creak..etc. I want something that is going to be there until I am dead.
Appreciate all the help.
-Nigel
Loctite PL Premium
-Nigel
